20 Most Recent Mitsubishi WS-55807 TV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage"
Mitsubishi... | Answered on Oct 12, 2016
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Mitsubishi... | Answered on Aug 01, 2016
Jack,
This Model Is Equipped With A Keyboard Lock Feature. To Unlock The Keyboard Press And Hold The "Menu" Button On The Front Panel For 10 Seconds. Then See If You Can Access That Menu Function.
Bill
Mitsubishi... | Answered on Jul 06, 2016
hi there, you have a power supply problem, check and dry up the damage are were the water goes and do some test at the power supply section first. ty
Mitsubishi... | Answered on Jan 27, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Mitsubishi... | Answered on Nov 01, 2014
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Mitsubishi... | Answered on Aug 31, 2014
nothing - if it is fine when it warms up, leave it alone
Mitsubishi... | Answered on Jul 27, 2014
if center dot yoke problem
Mitsubishi... | Answered on Apr 29, 2014
Panel should be suspected. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mitsubishi... | Answered on Apr 02, 2014
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mitsubishi... | Answered on Mar 31, 2014
delete characters by pressing cancel for each character
Mitsubishi... | Answered on Jan 07, 2014
Mitsubishi WS-55807 TV Logo
346 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi ws 55807 error code 24
  • Televison & Video
