Just bought a celera t.v. used and am searching for a master code to override the parental code that the previous owner set
If you forgot your password for this feature, press the following
buttons on the remote, one at a time. (Note: You must be in the
password entry screen) Press, Mute, Display,Clear and Reset, this
unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press
and hold Menu on the TV AND volume down on the remote for 3 seconds.
Nothing will appear on the screen, and the Parental Controls will
unlock, and you can re-enter a new password with the LOCK PARENTAL
CONTROLS
Try codes 3308 or 6688 to get past the pre set lock and then reset each tv rating. After all the tv ratrings have been set then highlight the passcode number, then use the left or right arrow on the code and the a white box will appear at the bottom of the screen where you can enter a new code. Then press menu to exit.
Thax this work! press mute display menu and menu again
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
You cannot change Parental
Control settings without
knowing the secret code. If
your code changes, someone
else has altered it and possibly
viewed blocked channels. Yet try the following procedure:-
Philips sets uses a four digit code to contro the V-Chip. The override code for Philips set is " 0711 "
OK.
the advise sounded right, I tried both methods to no avail. still have the parental controls on. But thanks for the input.
