20 Most Recent
Philips 50PF9956 50 in. HD-Ready Plasma Television Questions & Answers
Philips 50PF9956 50" Black Levels
Did you try backing down the contrast?...about the only thing I can think of would be issues with the main board if its not an adjustment in the picture settings in menu
I turn on my 50PF9956 get sound but no picture.
The plasma picture tube technology lasts only 24 months before it burns itself out, requiring a new
plasma picture tube. The LCD and LED technologies do not suffer from this short life span.
If your Philips 50PF9956 is over 2 years old, you've got all the use your plasma can give.
Fix: new plasma display - the electronics controlling the plasma display are most likely fine - just
like the electronics providing audio to the speakers. Your set's only problem is a burnt-out display.
Where is lamp location in polaroid 32 in hd tv
I'm not sure which TV you have. The Philips 50' plasma does not have a backlight. The Polaroid 32 can have a incandescent or a florescent backlight. The backlight is accessed by removing the back of the TV and replacing the lamps. There can be 1-4 of these light for florescent and 1-*** number of lights if incandescent, depends on the design, model, features, price point.
How do i reset my
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset
OK.
I have a 5 year
Normally the parts for this unit is a kit Y-SUSTAINBOARD and Z-SUSTAIN BOARD, this is what most manufacturers would want you to do, purchase them. But go to insert and go through all the voltage checks to find the bad part, here is also a chart that should help a lot
Still proper Diagnosis is required before you Order Any Part.
There is a Generic Troubleshoot Guide that would help you :-
http://www.mediafire.com/?kmyydjk2mil
Download and look at the same. You need to have Acrobat Reader to View this.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
No picture only audio
Check it again, when you have audio(sound) shine a flashlight on the screen (very close) Look carefully for a video image.
Please reply back to this post, when you start a new post everytime I have a hard time finding them.
Lone99star Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/jason_77a19afa8d604dee
No picture, just audio
Hi
I am happy to help, we need to check the backlight inverter.
- Turn tv on and get to a point that you have audio.
- Take a flashlight and shine it on the screen.
- Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Picture will not come on. only sound
Hi jsevcik897,
