20 Most Recent Dell W4201C 42 in. Plasma HDTV Questions & Answers
update the firmware.
Dell W4201C 42... | Answered on Oct 28, 2017
Sounds like the video card could be bad. Also make sure the connections from your cable box are securely tightened.
Dell W4201C 42... | Answered on Sep 28, 2017
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Dell W4201C 42... | Answered on Jul 20, 2017
You can change aspect ratio by remote. I hope it will be solve
Dell W4201C 42... | Answered on Apr 02, 2017
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Dell W4201C 42... | Answered on Jan 12, 2016
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Dell W4201C 42... | Answered on Dec 07, 2015
There can be many things that can cause a jumping or unstable picture. The power supply is the starting point. You would have to be able to monitor the voltage outputs to determine if there is instability.
Then there is the testing of the circuit boards by monitoring the proper waveforms, as per indicated in the service manual. You will require the proper test instruments for this. Once the defective board is found it will have to be replaced.
If the set is out of warranty, it may be more worth while to replace it. Servicing out of warranty can be too expensive to be cost effective.
Dell W4201C 42... | Answered on Oct 21, 2014
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Dell W4201C 42... | Answered on Mar 11, 2014
Dell W4201C 42 in. Plasma HDTV Logo
212 questions posted
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Televison & Video
Most Popular Question
old hp workstation xw8000 computer
  • Televison & Video
