Marantz SR-7200 Receiver Logo
Posted on May 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No Audio when I play Blu-Ray discs with Dolby TrueHD
BD player: Sony BDP-S500 (Supports Dolby TrueHD)
AV Receiver: Marantz 8002 THX Select2 Surround Receiver (Supports Dolby TrueHD)
When I play a BD disc which supports Dolby TrueHD, I dont get any audio through my receiver. I am using an HDMI cable to connect the Blu-ray to my receiver.
Thanks
jason
Level 3:
  • Master 905 Answers
  • Posted on Oct 06, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
321139
Points
2511
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Kristine
Level 2:
Sergeant:
  • Marantz Expert 294 Answers
  • Posted on Feb 26, 2020
Kristine
Marantz Expert
Level 2:
Sergeant:
Answers
294
Questions
0
Helped
171814
Points
904
Try Leawo Blu-ray Player which is developed with a special ability to fully cope with Dolby Atmos and Dolby TrueHD without issues. Inbuilt with various leading technologies for audio output, this TrueHD Atmos player is capable of supporting Dolby, DTS, AAC, DTS-HD, multi-channel sounds including 5.1 and 7.1 channels, etc.
1helpful
2answers
Is there a way to read Blue ray disc from Europe on a sony BDP-S1200?
No! Sony has kindly locked there BDP range of BluRay players to the region country they were made for only and not multi region.
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Cannot find out how to stream youtube through my sony dvd blue ray player
You need an ethernet cable connected from your modem to the LAN port of your player.
1helpful
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
1helpful
3answers
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
2answers
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
2answers
True HD - biggest secret
Are you playing a TrueHD format disc? Just like DTS 5.1 or any other format if your disc isnt coded in TRUEHD then your not going to get it. DTS or other formats cannot be "converted" to TrueHD like the video portion of a standard def disc. At this point there arent alot of TrueHD discs out but be paitent, this may change. Or not, due to the fact there are other "lossless" formats that may be more widely adopted. Sort of like DTS and THX were when DVD first came out. Hope this helps.
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
