20 Most Recent Yamaha RX-V663 Receiver Questions & Answers
The sub channel will be switched off. You need to find the speaker settings, locate the sub channel settings and switch it on.
Yamaha RX-V663... | Answered on Jun 26, 2017
It makes no sense that the dealer cannot find the problem. There are several areas they could be looking at and are not. The service manual is available,
Yamaha RX-V663... | Answered on Mar 18, 2017
You should be able to find remote codes and instructions for programing them on the dish network or direct tv websites
Yamaha RX-V663... | Answered on Jan 21, 2016
The error code that you listed indicates that the unit is shutting down due to the temp sensor triggering a fault. Most likely, there is bad connections on the temp sensor itself that will need to be resoldered.
Yamaha RX-V663... | Answered on Aug 05, 2015
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
Yamaha RX-V663... | Answered on May 09, 2015
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Yamaha RX-V663... | Answered on Jan 06, 2015
Ironic that this popped up today. I just worked on my dads Yamaha RX-V663 today. Have you tried to see if it works on the other speaker channels. Not sure how you have yours set up or how many speakers are attached, but my dads wouldn't work on channel A, I guess it burned up. I basically just moved the speakers over to the surround sound and channel B and everything worked as usual. Oh, and turned off channel A
Yamaha RX-V663... | Answered on Dec 16, 2014
Try holding the "straight" and "audio select" buttons and press power. this may return power if the unit is locked in protect.
Yamaha RX-V663... | Answered on Nov 24, 2014
it is probably in protect mode. Try holding the 'straight' and 'audio select' buttons and pressing power. See what happens.
Yamaha RX-V663... | Answered on Nov 17, 2014
Go to the Directv Remote programming Page and enter your device
It will give you the correct codes or a universal code for your brand receiver.
Yamaha RX-V663... | Answered on Oct 04, 2014
Yamaha RX-V663 Receiver Logo
237 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
repair power supply audio video receiver
  • Audio Players & Recorders
