Master
- Posted on Sep 18, 2010
Re: I can,t program my universal control,how i program...
Configuring codes:
- Turn on the component that you want to set up.
- Hold the component key down until the green indicator
light comes on. The green light should come on after approximately 3
seconds.
- Release the component key.
- If you are programming the DVD or CD device press the
"action" key. The red indicator light will come on.
- Within thirty seconds, enter in a 4-digit code number.
The component key lights will blink with an upward motion when a code has
been successfully entered. In this case proceed to step #5. If the code
has not been successfully entered, the componment lights will not blink.
In this case return to strep #1 and start over.
- Test code by pressing "Power" key. If the
component turns off, you've got the right code. Follow the same
instructions to set up your other components. If the component doesn't
turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes
turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up
your components without having to enter in code numbers. The Jensen will do the
work for you! (It may take a few minutes to find your code using this method.)
- Hold the component key down until the light comes on.
The green light should come on after approximately 3 seconds.
- Press "0" - "9" The green light
will blink as codes are sent.
- As soon as the remote turns your component off, press
the "action" key. (You have 1 second in which to press the
"action" key to save the code.) The component key lights will
blink with an upward motion when a code has been successfully entered. The
component is now programmed. To find that code, proceed to Code Readback.
- If none of the codes turn your component off, return to
step 2 and start over. Thank You
