2003 Chevrolet Suburban 1500 Logo
Anonymous Posted on May 15, 2008
Temperature guage 2003 Chevrolet Suburban LS 1500 - Where is the temperature guage that shows the outside temp on the mirror?
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on May 15, 2008
Anonymous
Master
Level 3:
Answers
1010
Questions
6
Helped
630838
Points
2385
Right behind the grill around the rad. support on the passenger side (usually) there is a sensor called an ambient temperature sensor. That gives your outside temp. on your rearview mirror.
My rear view mirror with temp and compass sometimes will not work. It will show all the digital shows up at once and not the temp, but sometimes it works ok. What can I do?
Does the compass work when the temperature goes out? If the compass still works then chances are that the ambient temp sensor is defective. Also, could be wiring to the sensor. If the compass goes out with the temperature then chances are the mirror itself is defective. Cheapest most common problem is the ambient temp sensor. It's behind the grill by the condenser at the front of the vehicle.
My temp guage is at 160. I notice my gas mileage was getting bad. what is causing this?
That could be your problem. The computer sees the temperature is low and reconfigures your fuel mixture accordingly. Replace the thermostat with a new GM unit. They are way better than the aftermarket stuff.
Trucks runs most efficient around 200 degrees.. Check air pressure in your tires air filter and you might try some fuel additive as well. Good luck!
How do you replacethe outside ambiance temperature sensor for a 2003 chevy suburban ?
Locate it unbolt it remove wire replace. Should be in front of the ac condenser behind grille. Get a picture of part from autozone.
2helpful
Chevy Suburban 1997 1500 won't start when Cold
it could be a tune up issue such as plug wires plugs . but my guess is its a computer engine temp sensor if it reads 5 degrees out of range it cuold give you a hard start or a no start problems the best way to look at this problem is with a scan tool when it is cold to see if the temp matches outside ambeint air temp 1 or 2 degrees ok b ut not 4 to five there is a nother way to check it buy useing dvom at a temp to omhs chart.
2003 Suburban LS 1500. A/C blows warm air when idling for ~3 min then returns to cold when moving.
Either the system is low on refrigerant , the electric fan is not working or the orifice tube is plugged. More than likely the system is low on refrigerant , have it evacuated and recharged.
1helpful
Can't get the outside temp. showing in the inside backview mirror
Check the connector that plugs into the back of the mirror and make sure it is pushed in all the way. If that is not it, look carefully at the wires going into the connector. I had one that broke off. I had to pull the pin out of the connector and re crimp it onto the wire.
Rearveiw mirror temp./compass ain't working
The overhead console is quite prone to internal failure. Dim, intermittent, or dead displays are a common symptom of an internal failure. We offer a reasonable repair service with a lifetime guarantee. Check it out: www.autoclockrepair.com
Heated seat
I have a 2003 chevy 2500HD extended cab that the right side window, seat heater, seat controls, door lock, will not work. all other windows and door locks work. I checked all fuses and they are good. what can it be.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
