Hi John, I would say it is leaking because the needle valve in the fuel sump isn't shutting off the fuel flow once the level is where it needs to be. The sump is vented to atmosphere so the fuel will gravity drain to the sump. The fuel sump has a float like a lawnmower carbuerator. You can take the sump out and clean it and that may help. Kerosene will sometimes gel after it has sit a while. Carb cleaner usually does a good job. Let me know what you find. My uncle worked on these heaters for 20+ years then trained me. I have an old non working Laser 55 that has some good parts on it if you are ever in need.
Testimonial: "I did exactly what you said and it worked like a charm. I thank you very much for your help. I will keep you in mind if I need parts from your old 55"
