20 Most Recent
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Questions & Answers
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
10/1/2022 12:37:56 PM •
Rinnai...
Answered
on Oct 01, 2022
Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
3/4/2022 11:32:15 PM •
Rinnai...
Answered
on Mar 04, 2022
Error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
4/7/2019 9:36:39 PM •
Rinnai...
Answered
on Apr 07, 2019
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
11/26/2017 10:25:42 AM •
Rinnai...
Answered
on Nov 26, 2017
Filter blinking light
Vacuum the back of the heater near the vent pipe and the sides near the floor.
12/17/2016 4:37:24 PM •
Rinnai...
Answered
on Dec 17, 2016
My gas wall heater only stay lit for about 5mins. Easy to restart.
First thing to try is to check the flue to see if it is blocked or even partially blocked. This type of flue assembly exhausts burnt gases from the heater and another section draws fresh air in to the heater to be mixed and burnt with the gas.
the centre of the flue is the exhaust section and the outer section of the flue is the fresh air intake section.
removing the flue cowl will allow a visual inspection of the flue for any blockages.
If the flue is a long run then a plumber may need to be called to disassemble the flue for a closer inspection.
2/16/2015 10:55:56 AM •
Rinnai...
Answered
on Feb 16, 2015
