Behringer Xenyx 1832fx Mixer 18 Input 32 Bus with Efx  USB Logo
Anonymous Posted on Sep 06, 2010
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn the volume up on the main mix level I get a very loud rattle sound coming from my pa system. also how can I control the mic volume to main mix volume! when I turn up the volume on the main mix the mic also goes up. I need to know how to separate the mic volume from the main mixer levels that controls my music to the pa. I have a cd that came with the mixer, do I need to down load the usb interface from the cd to my computer in order to eliminate any of the noises, rattling, crackling that is coming from my computer to the pa system! regards
  • Anonymous Mar 19, 2014
    i would like to know how you u usb connection on the mixer to play back music
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Sep 06, 2010
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2250487
Points
16163
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
  • Anonymous Sep 06, 2010
    Thanks for your advice, I'll check it out. QUESTION: What do you mean when you say loaded the support SW?
    Regards Col
  • Fred Yearian Sep 07, 2010
    You should have software specifically for the mixer loaded on your PC that makes external control easy and receives the audio over the USB link. If disks were provided with the unit, make sure they have been installed AND are compatible with the OS on your computer.
I had mxl v87 mic and i connected it to beheringer xenyx 1202 mixer but no sound is picked up What should i do
ensure phantom power is on and use xlr to xlr cable to connect to mixer. ensure that the channel is set tro mic and not line input. refer to mixer manual for more info.
Jun 14, 2018 • MXL Music
How to use the behringer 802 mixer and connect it to the computer
There are a variety of ways to accomplish this, but the two most common ways are:
  1. Purchase a BEHRINGER USB interface -- like a U-CONTROL UCA222. This will allow you to use the USB port for your sound In/Out. This will also require RCA cables to connect from mixer to UCA222 unit.
  2. Or...purchase a dedicated sound card (preferred) like an M-Audio Audiophile 2496 that can be installed in your computer (not for laptop). You will also need I/O RCA cables to connect.
Qfx1222 usb/hp envy computer - no sound frm mp3 music files
When you connect your laptop to the behringer mixer via USB it effectively uses the mixer as the audio interface.
You will need to hear the audio through the mixer either through headphones or external speakers.
There is no way that I am aware of that you can route all audio back through your laptop's speakers.
Mar 16, 2017 • Music
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
I cant figure out how to connect my xenyx 1832 fx to my desk top computer
alcuni canali non funzionano metto il microfono e non va lo metto in un altro canale funziona come mai? salve e grazie gioago 1
How much output power supply behringer xenyx 1832fx?
The supply will be similar to that in the 1222. Download a schematic here. Look at the SPUS2 portion of the compressed file.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
There are several voltages present.
Output form computer to board using USB works but the signal for input doesn't work
In the control panel, "sounds and audio devices" under the "voice tab" make sure the INPUT is set to the Xenyx device.
I need the part number for the volume slider on a 1832 fx mixer p
I don't think you require a part number for your mixer, ring the company and tell them what model you have and I'm sure they will be able to assist you in regards to your volume slider.
regards Col
How do i set a behringa 1832 fx mixer
I have a behringer 1832fx mixer and have the manual that illustrates how to set up for a band and/or other instruments etc! is this is what your asking for?
regards Col
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
