20 Most Recent Yamaha Mg82cx Stereo Mixer Questions & Answers
0answers
I have no monitor signal
A little vague, there, Chuck... We have no idea if you even know how to plug the thing in... an no, it's not obvious because some people don't. Describe your connections and a little more about the problem.
6/2/2014 9:34:09 AM • Yamaha Mg82cx... • Answered on Jun 02, 2014
manual
Mg82cx Stereo Mixer Manual
Yamaha MusicUploaded on Aug 19, 2013
Confuse about the jack
Both stereo and mono jacks will work fine on the inputs, any guitar or mic lead will work a treat.
You can use stereo jacks for the outputs too, but to keep it simple just use a mono jack in the L out and a mono jack in the R out.
1/15/2013 7:51:40 PM • Yamaha Mg82cx... • Answered on Jan 15, 2013
2answers
I HAVE THE YAMAHA MG82CX
there is a main output, conect it to the aux in line or to the microphone line.good musics
11/17/2012 2:26:51 AM • Yamaha Mg82cx... • Answered on Nov 17, 2012
I want to connect the
Couplers and adapters available at any Radio Shack
8/20/2011 10:16:57 AM • Yamaha Mg82cx... • Answered on Aug 20, 2011
When i record i can
If your mic can "hear" the beat, it will record it as well with a reverberation that will NOT be pleasing. Maybe you can use headphones to avoid that.
7/14/2011 5:00:02 PM • Yamaha Mg82cx... • Answered on Jul 14, 2011
0answers
NO MANUEL
7/27/2010 6:06:13 PM • Yamaha Mg82cx... • Answered on Jul 27, 2010
Yamaha mg82cx locked up, all led's on, no audio
Check the power adapter. It is a 38 volt AC centertapped unit with 0.62 amp rating. Verify that you get 38 volts AC between two of the pins and 19 volts AC between any other pair of pins with an AC voltmeter.
Check that the connector is seated. These can sometimes seem to be seated but not fully in place.
4/25/2010 12:21:10 AM • Yamaha Mg82cx... • Answered on Apr 25, 2010
2answers
I have a yamaha mx124 mixer, when i turn it on the
The most common cause of this is a failure of an internal op-amp IC. While the part itself is inexpensive, access to it is tricky. These models also use surface mounted devices which are more difficult to replace without the proper equipment and practice. This repair should not exceed $100 in total cost. The parts will run about $5 or so.
Dan
3/15/2010 8:33:49 AM • Yamaha Mg82cx... • Answered on Mar 15, 2010
Thanks for using FixYa.
There must be something wrong hardware wise with the two channel ports. Try to have your mixer checked for any busted capacitors.
I hope this helps. Thanks and good day.
-HotRatchet
3/14/2010 1:27:25 PM • Yamaha Mg82cx... • Answered on Mar 14, 2010
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
1/2/2010 7:42:01 PM • Yamaha Mg82cx... • Answered on Jan 02, 2010
Where can I purchase a European compatible power
what is the voltage/current/wattage of the unit this info should be on the back/underside of the unit, Also what type of power supply plug does it take? Maplin electronics throughout the uk or any good electronics parts supplier should be able to help you? Have you tried ebay etc?
7/14/2009 10:25:36 PM • Yamaha Mg82cx... • Answered on Jul 14, 2009
Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
2/2/2009 5:20:13 PM • Yamaha Mg82cx... • Answered on Feb 02, 2009
Can one reset psr 950 yamaha keyboard?
Follow the Yamaha guide I sent you. https://uk.yamaha.com/en/support/updates/firm_psr-s950.html
4/22/2024 6:51:02 AM • Yamaha Music • Answered 3 days ago
What could be the cause of psr 950 yamaha keyboard after booting it will write unexpected error?
Usually that is caused by corrupted software. Try reloading the firmware. https://europe.yamaha.com/en/support/updates/firm_psr-s950.html
4/22/2024 6:30:14 AM • Yamaha Music • Answered 3 days ago
Will a midi interface allow me to play downloaded music on a yamaha clainova 305
Yes, with some preparation. The music will have to be in a standard MIDI file format or a format that results in standard MIDI over USB output when "played" by computer software or an external sequencer. Within the software you will probably need to create a new "instrument" if there is not already a template for the CVP 305, otherwise the tracks and sub channels in the MIDI file will be patched to GM, probably not what you want to hear.
2/17/2024 11:28:18 AM • Yamaha Music • Answered on Feb 17, 2024
Yamaha Mg82cx Stereo Mixer Logo
Popular Tags
19 questions posted
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
yamaha mg82cx locked up all leds no
  • Music
