SOURCE: Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
SOURCE: motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
SOURCE: V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
SOURCE: Tracfone screen says "charge complete", phone won't turn on.
remove battery for a few min. then reinstsll and charge again
