Behringer Pmp3000 16 Channel Audio Mixer Logo
Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i hook up a seperate power amp . to the pmp 6000 powerd mixer . for more over all power.
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on Aug 20, 2010
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2250550
Points
16163
You can add extra amps driving ADDITIONAL speakers... you CANNOT parallel amps driving the same speakers.
Drive these seperate amps from the MAINS OUT connnectors using TRS and balanced lines to those external amps.
Our Behringer pmp 6000 just recently mysteriously lost both monitor 1 & 2 signals. Please provide some suggested resolutions? Is there anything other then the channel monitor level knobs and the main...
Try plugging in a set of headphones into each of the mon left and right. If the monitor sliders are up AND the channel monitor knobs are up you should be able to hear in ONE SIDE only of the headphones. If not, then you may have failed to power your monitor amp or speakers from the SAME receptacle as the mixer and this can result in ground bouncein building wiring that will blow out the driver chips for the mon signals.
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
[ replaced the speaker b0ard but the speak 0n c0nnect0rs d0 n0t work ! can i hook up another way to get out put to the speakers
What is a "speaker board"??? Nothing like that listed in the parts list.
Likely the power amps are dead... the common cause of the problem.
We set up the monitors in our pmp 6000 at the mon send jacks but we didn't get any sound from it when we turned up the monitor volumes. What is the proper way to set them up?
I HOPE you know that the monitor send jacks are NOT powered. You MUST use either powered monitors or an external amp for these to drive speakers. Assuming you have done that, you have to turn up one or both of the monitor knobs for each channel you wish to send to the monitors at the desired level. Then you advance the monitor faders for the overall monitor level.
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
1helpful
What is the best powered mixer to go with my b215xl 1000watt speakers
The PMP 6000 or 4000 depending on how many channels and effects you need is a good match.
READ THE SPECS... the speakers are capable of 250 Watts RMS (not 1000 as that is PEAK) power... like the ridiculous claims of 4 Hp for shop vacuums that run on 120 volts.
The 4000 and 6000 will generate about 250 Watts per side into 8 ohm speakers so is well matched for the B215XL speakers... by matched we mean the speakers are not likely to get blown out.
Connect a 500 Watt per side amp to the speakers and you will be buying replacements in short order.
ALSO realize how much sound you will get from the speakers.. they will cover a 2000 square foot venue fairly well. I suggest you get a sound level meter so you have a metric of levels when you are using the system. If you need more sound, you can add a second set of the speakers in parallel.
Hook up eventide harmonizer to the pmp 6000
There are many models of the Eventide and how to hook them up will vary and depend if you have multiplle mics that are to be serviced. If you have multiple mics, I would be tempted to run the mics into some of the channels of the PMP but tur their faders to zero and send them to MONITOR 1. Come out of the MONITOR 1 jack to go into the Eventide and then run the Eventide into one of the line inout channels like 19/20. You would need to use balanced connections and some adapters from XLR to 1/4 inch to make the connections. There are MANY ways to configure this and depends what you are trying to do. If all audio is to go through the Eventide, then wire it as an "INSERT" for the power amp. This would require a special cables.
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
2helpful
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
