20 Most Recent Behringer Pmp3000 16 Channel Audio Mixer Questions & Answers
Your question appears in the Food Mixers category, which appears to be a mistake using the word mixer..
I searched the internet using Google.com and only found the dmxp6 mixer for sale, but not a manual.
You might try contacting the manufacturer of technical pro mixers.
https://www.tpro.com/pages/technical-support
Behringer... | Answered on Dec 12, 2018
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Behringer... | Answered on Feb 18, 2018
Di you mean this one? -> http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
You can download Service Manual of Behringer PMP3000 free of cost on below link:
https://www.electronica-pt.com/esquema/audio/behringer-audio/behringer-pmp3000-16040/ Behringer PMP3000
A passive loudspeaker requires an amplifier to increase the power from the mixer.
An active speaker does not require an amplifier and will work direct from a mixer as the amplifier is built into the speaker box.
Behringer... | Answered on Jan 20, 2018
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Behringer... | Answered on Mar 19, 2017
You don't say which QSC Amp. Assuming it is one that can only drive down to 4 ohms you are going to have to run a pair of the jbls in series for each channel of one amp (making the impedance 8 ohms for the pair) and run the other pair from the channels of the other amp. Running unbalanced is not a problem except for interference but you don't say what the source is. If you have more than one output (aux or sub bus for example or poss even a monitor output if you're not using it) it may be beneficial to take one amp from there as you will have some control over the relative levels from the mixer. Otherwise you'll just have to parallel the amps.
Behringer... | Answered on Jun 03, 2016
Here is a google link. I don't know which one you need.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=circuit%20diagram%20of%20behringer%20power%20amp
Behringer... | Answered on Apr 29, 2016
There is a jumper (JP1 or J1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. See the pictures about my project. :)
Behringer... | Answered on Aug 11, 2015
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
Behringer... | Answered on Mar 09, 2015
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
Try http://elektrotanya.com You can download 2 circuits per day for free, or pass an electronics test & create a login to get access to more.... Good Luck!
Behringer... | Answered on Dec 22, 2014
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Behringer... | Answered on Jul 12, 2014
Visit this page:
http://www.behringer.com/EN/Products/PMP3000.aspx
Or google for:
Behringer Pmp3000 filetype:pdf
Cheers!
Behringer... | Answered on Apr 29, 2014
Behringer Pmp3000 16 Channel Audio Mixer Logo
213 questions posted
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
no audio from main speakon outputs b
  • Music
