SOURCE: cybershot DXCS60 carl zeiss vario-tessar
There is a switch at the back of the sliding cover of the lens that is on when the cover is slided down (lens uncovered). You should try to take off the back cover of the camera where the sliding cover is and try to fix that switch.
SOURCE: no manual
here it is download it and rate me FIXYA for help
DSC-S60
http://www.docs.sony.com/release/DSCS60-90.pdf
SOURCE: Camera says "reinsert memory stick".
use sony memstick. try formating the stick. you will lose any picts when formating. try inserting in cpu that has memstick slot.
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
