20 Most Recent Sony Cyber-Shot DSC-S60 Digital Camera Questions & Answers
Using AA+ batteries camera shws pic sbt shuts off on camera mode
Nicad batteries only hold 1.2 volts.each...the older cameras need the alkaline which are 1.5 volts as that brings the voltage to 3 instead of 2.4
11/21/2017 12:06:50 AM • Sony Cyber-Shot... • Answered on Nov 21, 2017
Lost USB Cable, Dont Know Where to Find Replacement
comusa or any computer store should carry mini usb to usb cables.
4/28/2014 12:50:34 PM • Sony Cyber-Shot... • Answered on Apr 28, 2014
3answers
USB cable for Cyber-shot DSC-S60 no longer works
buy a new usb cable..
8/31/2013 4:31:11 AM • Sony Cyber-Shot... • Answered on Aug 31, 2013
2answers
Sony dsc-s90
Many digital cameras have a 2nd disposable battery to remember settings like date and time, and where to put the pictures, when the rechargeable battery is removed,, but I don't believe that is the case with your camera. possibly you are not actually getting the time set correctly, since the camera will continue to ask for time & date setting every time the camera starts, if it is not set properly when it asks. Concerning internal memory- Can you transfer the images from internal memory to the memory sick when you do insert it, or is there a chance that the memory stick is defective, and therefore the camera doesn't record to it?
7/30/2013 2:54:20 AM • Sony Cyber-Shot... • Answered on Jul 30, 2013
2answers
I possess a Sony DSC-S60.
Your pictures are corrupted.You can recover pictures from memory card with this
1. Do not save any new photos into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your currupted pictures.
2/9/2013 8:28:29 AM • Sony Cyber-Shot... • Answered on Feb 09, 2013
2answers
Lens are stuck open on cybershot S90.
i would suggest you to contact any expert or SONY SERVICE CENTER because according to the problem you describe is technically difficult and due to jurk the gears of the zoom lens assembly may be broken misaligned, and there is a specific method to open the zoom lens assembly to change the gears, Or the if you want to repair it by yourself then you have to replace the complete lens block assembly, Therefore i would advise you to contact any expert for repair,
11/1/2011 5:47:34 PM • Sony Cyber-Shot... • Answered on Nov 01, 2011
My Sony DSC-S60 camera lens
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
9/10/2011 5:24:57 PM • Sony Cyber-Shot... • Answered on Sep 10, 2011
It just keeps showing access
First off remove the memory card and try and see if it works.
Is the lens extending out? If not is it trying extend but is jammed? If so give the lens a light but firm tap on your knee as you power it on to see if it frees up.
5/3/2011 10:05:28 PM • Sony Cyber-Shot... • Answered on May 03, 2011
Cant upload pics from sony
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/12/2011 9:26:49 PM • Sony Cyber-Shot... • Answered on Apr 12, 2011
Lenswon,tretract
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
4/10/2011 7:41:36 PM • Sony Cyber-Shot... • Answered on Apr 10, 2011
When i turn my sony
Back up your pictures and then format your memory card. You'll find the instruction for format your memory card on user manual.
3/14/2011 10:48:02 AM • Sony Cyber-Shot... • Answered on Mar 14, 2011
Camera will not flash
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When shooting in the Twilight or Handheld Twilight mode
If shooting with the Burst or Multi Burst mode
Shooting with Sweep Panorama
Shooting with the Fireworks or High Sensitivity mode.
If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged.
If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
3/9/2011 11:47:05 PM • Sony Cyber-Shot... • Answered on Mar 09, 2011
Lenswon.tretract
Factory advice is use fresh battery or AC adaptor to turn camera on and off to get lens to retract, but in all likelyhood, your camera needs repair.
2/19/2011 8:24:14 AM • Sony Cyber-Shot... • Answered on Feb 19, 2011
How do I delete pictures from the memory
Before you delete them I highly recommend saving another copy of the downloaded files by saving on a dvd usb, or an external hard disk. You never know when the computer may crash or the files accidentally deleted.
The images on the card can be completely deleted by clicking the format card command. You will be asked if you are sure and that all the files will be deleted you click ok or delete. Inside the camera the format card command can be accessed from one of the menu settings (same place you set the date and language. Of course you can also delete individual photos, for example after shooting a bad shot, by pressing the delete button (it looks like a bucket).
You can also format the card without the camera using a card reader. Attach it to the computer by USB and go to My Computer where the card will appear as D: or E: .Right-click there and you will see the format command. Or simply open the files select and delete.
Thank you for rating this fixit solution.
2/11/2011 2:05:32 PM • Sony Cyber-Shot... • Answered on Feb 11, 2011
When I turn camera on, the display shows the word
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
2/8/2011 1:31:24 AM • Sony Cyber-Shot... • Answered on Feb 08, 2011
Sony Cyber-Shot DSC-S60 Digital Camera Logo
Popular Tags
72 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
possess sony dsc s60
  • Cameras
