If you have cable television then the setting would be catv and set the settings to auto program. It will take it a while but they will all show up.
Need more details. Is it an hdmi hookup or a coaxial? Is your cable line hooked up directly to the TV or are you using a modem? Is it a smart TV or just regular?
SOURCE: how to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
SOURCE: disney princess 13" tb p1300 ntv
disney will replace for around 30 dollars. Google disney customer service and get number is you are interested.
SOURCE: unlock codes
Found the code on another posting:
1,2,3,4
When the parental block comes up hit play, enter the code, then hit play again...
SOURCE: Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
Hope this helps
disney 13" princess tv, any suggestions? You can "manually" find your code by 1. pressing
