Panasonic KX-P2130 Matrix Printer Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I connect the 2130 to a windows 7 PC? Can I get a USB adapter to go from the printer to the pc? The PC does not have a parallel port and I do not have a driver disk (the PC doen not have a FDD)
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Aug 16, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557696
Points
31058
You can purchase a PCI add-in card, to add a "parallel-port" into your desktop computer. Then, connect the printer to this new port.
Hp 5500 printer
The HP Color LaserJet 5500 and the DesignJet 5500 are older printers with a parallel port on the basic model. A network card was added or available as an after-market add-on; this would connect to a router or network switch. Assuming you have the basic model and your laptop is new enough to only have USB ports, you need a USB to parallel port adapter. http://www.amazon.com/electronics/dp/B0007UVRVO is one model. (Note: the parallel port on the printer is a bi-directional port; you will need an adapter with bi-directional communication.)
I hope this helps.
(According to the HP site, the driver for the LaserJet 5500 should be available from the Windows 7 Windows Update feature. For Windows 8, you will need to download and install the Dot4 program before the printer will work. See http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=83880&prodTypeId=18972&prodSeriesId=83875&swLang=8&taskId=135&swEnvOID=4132 for the file If you have a different OS, see the HP site for your printer driver information.)
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
1helpful
2answers
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
1helpful
Trying to connect my toshiba laptop (Win 7 64 bit) to HP 4050tn printer with usb cable in laptop to parallel port on printer.
Well, that's not an easy combination... You have to find Windows 7 drivers for your USB to Parallel adapter cable - if it's some Chinese unknown brand product you might not be very successful.
If searching for drivers for your exact model fails, you can try to find out what chip is used inside the adapter and look for drivers for that particular chip. The chip symbol is sometimes mentioned on the box, and also you can try to read it from any other drivers you may have available for your adapter (look into the .ini or .inf files, opening them with Notepad).
2helpful
3answers
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
2answers
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
2answers
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
1helpful
I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge.
1helpful
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
