20 Most Recent
Panasonic KX-P2130 Matrix Printer Questions & Answers
Caution hot plate over ink
problem is not with your ribbon cartridge. the problem is in your printer's heater. check your printer heater
6/1/2011 4:54:49 PM •
Panasonic...
Answered
on Jun 01, 2011
When I switch the printer on it jambs.
There is a small limit switch inside on the left side that can get bent and causes this. It needs to be in the OPEN position when the printhead is to the right side and it closes when the head slides over it. Look for it, it is obvious. Now, bending it back is not a slam dunk but maybe yours is an easy bend back in place. Mine is taking more effort. I have removed the top to work better with it and removed the screw holding it down. I might have to un-solder the two wires to pull it out and put it on my workbench under strong magnification. Good luck.
9/4/2009 4:36:01 PM •
Panasonic...
Answered
on Sep 04, 2009
KX-P1124 Dm Printer -- Cannot clear the buffer, keeps printing garbage
Put one page in printer and tape paper so it will not feed as buffer print out data on paper.
May take one minute or one hour, that depends on how many times you hit the enter on keyboard
You must let the printer keep printing no matter if it is one word or one letter. Some old printer do not have cancel on printer, only thru computer or program. I have three in serv. from the 70's
A buffer happen and will always happen after it get information from computer. It takes many sheet of paper
Bob
10/25/2008 3:38:17 AM •
Panasonic...
Answered
on Oct 25, 2008
