20 Most Recent
Nikon COOLPRINT Thermal Printer Questions & Answers
Differences between right click and double click
In Windows based system, the double click (of the left mouse button) selects an icon and send the run or execute command. The right click (of the right mouse button) opens up contextual menu options, i.e. menu options that are related to what you are doing on the windows that has the focus.: if it is a disk it may offer you the choice to explore, format, erase. For an executable file it might offer you to run it, or to delete it, etc.
Virus Problem
What are your symptoms? What I mean is, how do you know you are infected with viruses?
Many times problems stem not from viruses, but malware like adware and spyware. These malicious programs can be detected and removed using anti-spyware programs like MalwareBytes and SUPERAnti-Spyware.
You can download them here:
MalwareBytes:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
SUPERAnti-Spyware:
http://downloads.superantispyware.com/downloads/SUPERAntiSpyware.exe
Hope this helps!
I want installer of hp
You can download the printer software/driver that you need to install it to your computer, just click
HERE and select the operating system of your computer and proceed with the download.
Difference between electrostatic and inkjet
This sounds like a "homework" assignment.
An electrostatic printer puts electrical charges onto a drum.
Then, dry "powder" ink is put onto the drum.
The ink sticks only to the charged points.
A piece of paper is rolled against the drum.
The "fuser" heats the paper, and melts the ink into the paper, permanently "fixing" onto the paper.
An ink-jet printer shoots microscopic drops of wet, heated, ink onto the paper.
The ink dries into the paper.
Prints test page but not documents
It means that your printer is working fine but there are some settings conflict which makes problem to print your documents.
So try uninstalling all the drivers and softwares related to your printer and reinstall them using the cd which came along with your device to resolve the problem.
Then you should be able to print your documents as usually.
Thanks
Getting error message the current port is not
Hi there
Go to start and then go to your settings control panel and then click with your mouse on printer and open printer then click on the printer icon you using with left side mose to properties then you will see the tab says port just try a dierent port till you get it right
All the best Pineworks
Can't print both sides with new OS on Mac
You sometimes have to do it manually. What I mean is is will stop you after is prints the first side and you have to than put the paper back into the paper tra and then press ok to the box that should pop up. If the box does not pop up, then I don;t know.
When I turn on my HP C6180, it wants to align the
mostly yes, the sensor is what is responsible for paper alignment. how ever you can try keeping an a4 size as all the printers tend to adopt default settings and work with it. place your paper correctly in position and then you can select the a4 and try printing a page.
Hp deskjet F380 printer driver
Get on your web browser (Internet Explorer, Firefox) go to
HP SUPPORTenter your printers model number and it will take you to the download page.
You can then download the latest drivers for your printer at no cost. Drivers for Windows XP, Vista and maybe even Windows 7.
Thank you for choosing Fixya!
How do i refill a brother mfc-465cn ink cartridge?
these cartridges are not realy designed to be re filled, cartridges need to be filled under vacume to work properly or its hit & miss as to whether they work or not, i would recommend you buy some compatibles localy or on the internet they are very cheap.
