Please confirm that unit gives sound output on System Connector J1103
I have schematics of this unit and can assist you to hook RCA jacks for all 5 channels output (L+R+C+SL+SR)
Thanks.
Yes - the unit sound output is from the System Connector J1103.
Great, Below is image of system connector schematics and pin configuration is as follows:
1 - Left
2 - Right
3 - Surround Left
4 - Set-up (detection of jack)
5 - Surround Right
6 - Subwoofer
7 - Center
8 - Switch (for amp activation)
9 - GND
Hope these info will help you.
This image looks better
if you put 12 volt + on pin 8 and 12 volts - on pin 4 sub goes online i am good gr paul out of holland
Wrong!!! 9- and 6+, you're welcome
A simple solution is to use a cable P2 to RCA connected in the frontal headset output.
Hi.
You should be able to find all schematics and wiring diagram using service manual below. First link is free and links to PDF document.
Service and Repair Manual.
Service manual also available here. Subscription needed.
Re:First link did not work.
Right click on the link and choose Save File As. I double tested and it works. Here link
Sorry about the bad feedback, solution will be passed to a different expert.
Bye.
First link did not work. Other than buying a new sub-woofer, is there any way to get audio out of the receiver?
Thanks
Great - thank you!
