20 Most Recent JVC TH-M505 System Questions & Answers
Well i had exactly the same problem, my sub turned off right away when i turned the whole thing on. Well i opened the subwoofer and was trying to find out something unusual, i took out, i believe, internal amp, well, whatever that thing is, under the lid. Which one is screwed with 6 copper screws, so you unscrew those screws, lift that lid and that whole board comes out. On that board i find something like burn around one of the parts.
http://www.flickr.com/photos/28004328@N04/3333561417/in/photostream/
you can see it in the pick, the part q2902, then i contacted JVC. At the beginning they said i need to take the whole thing to service center and so on. But later i made them to tell me what kind of part that is, so here :http://www.jvcservice.com/store/ProductDetail.asp?Part=KTC3199/GL/-T
bought soldering gun in home depot for $15, returned after i was done. And that is it, just have to replace it, but total cost only $12 ($5 part +$7 shipping)
JVC TH-M505... | Answered on Mar 03, 2018
It may be wired wrong ..polarity.
JVC TH-M505... | Answered on Feb 18, 2018
Please confirm that unit gives sound output on System Connector J1103
I have schematics of this unit and can assist you to hook RCA jacks for all 5 channels output (L+R+C+SL+SR)
Thanks.
JVC TH-M505... | Answered on Feb 03, 2018
MOst of the time it is the jack that the cable plugs into that has the problem. .
Also the jack is not broken but HAS broken the solder connection TO the jack.
If you know someone who can safely take it apart and solder, let them try.
JVC TH-M505... | Answered on Apr 13, 2015
TH-M505 can display in black in white if connected iimproperly using COMPONENT connections or if cables have gone bad. Try replacing component or changing connection to COMPOSITE. Does it play in black in white using COMPOSITE?
JVC TH-M505... | Answered on Jul 28, 2014
142 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
find sp pwm505 cable
  • Audio Players & Recorders
