Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
