HP PSC 1210 All-In-One InkJet Printer Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp1210 printer does not work on window 7 os
Level 3:
  • HP Master 6,688 Answers
  • Posted on Aug 05, 2010
Cindy  Wells
HP Master
Level 3:
Answers
6688
Questions
0
Helped
3533096
Points
21745
This all-in-one should work with the drivers built into the OS. First make sure you have a good data cable (go for a direct cable connection - no USB hub or print server). Next check for updates in Windows Updates. I've had a few printers where the new hardware was found but the driver update was held in Windows Update.
I hope this helps.
(please note that the scan and HP Essentials buttons will not work with the OS driver)
1helpful
My i9900 canon has gone spontaneously from working fine to stubbornly "offline". I decided just to delete and reinstall it, but can't find the CD or its equivalent online. Any help please?
What OS do you have? Please add the update version for Windows 10. The drivers are still available from Canon here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/i-series/i9900?tab=drivers_downloads for supported OS versions. It looks like the printer used Windows Update for to install most of the drivers under Windows 7. There is an optional update for the driver on the site but it doesn't work unless Windows Update installed the basic driver. The Canon didn't officially support the printer for any OS after Windows 7.
The Windows 7 driver worked under 8 (8.1) and some versions of Windows 10 for a while. (Under Windows 8, the ZoomBrowser software didn't work.) Then Microsoft became strict about not allowing unsigned drivers to install. The easiest solution is to find an old Windows 7 computer to connect to the printer. Alternatively, get an unused install license and build a virtual machine to connect to the printer. Note: recent cumulative updates for Windows 10 have caused issues with USB printers.
If you are using Windows 8 or 8.1, try connecting the printer via the USB port with the machine off. The restart the computer; make sure that the Windows Update is set to find updates for other devices (not just Windows). If you are using the printer over a network, some found using the Canon ProMark 9000 series drivers worked.
I hope these ideas help. I wish that I had better news for you about Canon support.
(Building a virtual machine OS depends on your CPU allowing virtualization and free memory. You also need the Windows Pro or Enterprise versions of the OS for Hyper-V (Windows 10) or the Windows 8 VM equivalent. Third-party tools for creating a virtual machine may work on the home edition.)
How do I make my hp1210 printer my default printer
In Windows-based systems, you open the Printers and other peripherals folder. Point to your printer with the mouse cursor and right click. In the drop down window that opens check the seb-menu option MAKE DEFAULT.
2answers
I want to download driver for printer how can i get downloader so i can use the hp1210 printer
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Cannot install drivers for Canon MF5550 on Windows 7 64 bit O.S.
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://www.makeuseof.com/tag/3-resources-windows-7-printer-drivers-printer-working/
My printer is not supported for windows 7 64 bit, how can i run my printer correctly?
Your Windows 7 operating system is not compatible to your HP printer. Your printer only in working only for Windows xp windows 2000 and Windows vista . Check your manual for OS requirement. Your need to use either any of OS i mention to be able to install your printer Requirements Win XP/2000/Vista
Windows 7 and hp1210
Windows 7 is still a beta and not all drivers exist for this operating system. Your best chance is to try if the driver for Windows Vista or XP would work. And try that with the Administrator privilages "on". If that fails try with the nearest alternative model drivers of HP. Good luck.
Hp director won't open 1210 psc
hey if you go to hp.com go faq you will find your question and it will direct you to an updatefor your problem its because hp director has issues with internet explorer 7 and 8 hope it workes
Scanner is not working.
hp 1210 will not work in a dual boot computer. I had to uninstall from XP Pro. I now can scan using Window Photo Gallery. ps now the scan botom will work
k24674
Grand Canyon Tech
Grand Canyon Tech
