2000 Harley Davidson FLTR-FLTRI Road Glide Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a 1980 FLT and orignally the battery was bad so the bike had to be jumped...however it did jump and run great. Now the bike even with new battery will not even attempt to start. Any suggestions?
Arnie Burke
Level 3:
  • Harley Davidson Master 7,339 Answers
  • Posted on Aug 05, 2010
Arnie Burke
Level 3:
Answers
7339
Questions
0
Helped
1823965
Points
21459
The batt is probly not rechargin-test alternator and regulator or search for flaws in wirin
08 Chevy Cobalt wont start. Battery is good.?
Generally speaking, if the starter was dead it would not jump start.
Sounds like the key switch or the neutral safety switch.
You would need to know if the starter has power when the key is in the start position.
2answers
BMW 1200 rt no electrics
test batt for holdn 12.6volts and maybe test alternator too----a relay cud be bad or connections need titening
1helpful
2answers
Last year the Battery Died, once the Battery was replaced and charged(Using a trickle charger), the Bike has not turned back on. It clicks as if its trying to spark (like when a car needs to be jumped) but...
Hi, firstly you are probably rite about the clicking being related to a discharged battery, i would suggest you try some jump leads of a car or another battery my guess is it will start or turn over and the clicking will stop, suzuki motorcycles of this eara did have some charging probs, running with a discharged battery for a prolonged period is not recomended.
Secondly its not unusual for even a new battery to become low state even when left continuasly on chage with a trickle charger, and eventually the battery.becomes dead through overcharging
Just bought a bike and the battery was bad .so i tried to jump it off with a car and it stop trying to turn over at all. went and got a new one and it's still not turning over.
It may have blown a fuse,
Be carefull jumping of a car battery, as when it starts and you give it a rev the car battery will accept more current than the bike can produce and can damage the charge circuit.
1980 Suzuki GS450, jump started my bike and now no spark, I blew the main fuzz, replaced it but still now spark, could the Igniter have gone bad or other ignition related problem be why it has no spark, I...
It is OK to jump start your motorcycle from a car battery as long as you do not crank the starter too long (it will burn the armature) and as long as the car/other vehicle is not running when you jump start your bike ( you can damage your electrical components( igniter box)). See if you can exchange one with a friend to see if that is the bad component.
2answers
Hi, I own a 2005 R1 for a year now and about 2 or 3 months ago I felt that the battery maybe low, I tried to cherge it but it didn't help much. I bought a new battery today and after installing it the...
ur alternator or voltage regulator has issues-batt is not being charged--havum tested with a multimeter--inspect wiring 1st-may be loose or corroded
2helpful
2answers
Bike wont start , the solenoid just clicks
If you push the start button and the solenoid clicks the button is good. Find the solenoid ( usually by the battery follow the positive cable.) and jump the two posts with a screw driver, piece of wire , or jumper cables if the starter now works you need a new solenoid. At this point you either have a bad battery or a bad starter. Jump the bike with a good automotive battery (can be in the car just make sure car is not running or you could damage bike.) If bike starter still does not work try new starter brushes for a Goldwing they are cheao and easy to replace. If brushes look good ( not down to wear marks ) you need a starter ( bad armature ). I'm guessing the solenoid is bad (first choice) or you need brushes. Good Luck
Trx 850 just serviced.new plugs and battery.turning over freely.smell off petrol but will not start.bike only ran out two or three times last year 'i have had it running last week but had to jump start...
if u have a bad battery in it u r not gonna run right or at all even jumping it off if u have a new battery trychanging the gasif the gas has sat for 3 months or longer it goes bad and cloggs up carburator and if thats he case ur gonna have to pull ur carbs and clean the thoroughly
1helpful
Bike runs fine then stalls when ya try starting again it wont as battery is flat is this common on xs 1100 1980 bike will start no trouble via a jump start
If you have a voltage tester you will probably find a low reading on your battery. It takes a big powerful battery in excellent condition to start that monster, that's why it starts right away when you jump it...Good Luck to you !...Tim
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
