Verizon Communications HTC XV6800 Cell Phone - Blue Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My verixon htc VX6800 screen will not show up but the phone is on. the screen will light up black, but the home screen wont actually turn on. i can recieve calls but can't see thephone. how can i fix this problem at home?
Anonymous
Level 3:
Genius:
  • Master 1,196 Answers
  • Posted on Aug 02, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1196
Questions
0
Helped
209700
Points
3559
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Have a HTC Phone, It comes on and won't let you do anything and goes black. How do I get in it to do anything?
If there's no removable battery, leave the phone on until the power is gone, then charge and it should work again.
My htc vivid will not turn on. when i charge it the orange light comes on and then the light goes away. the screen turned on showing me the batterary and it says that it is at 90% but it still wont tu
Just guessing, but if battery is removable try taking it out and leaving it out a minute or two and put it back in and see what happens?
Jan 02, 2015 • HTC Vivid
My motorola android verixon got wet and the screen turns on but the screen wont work now
first of all take out the battery and blow the hot air to make the phone dry form back or you can use hair dry instead even if it is not working then change PDA
May 21, 2013 • Cell Phones
The screen on my htc desire s has gone black and the phone wont respond
I solved this problem few times by completely opening my HTC Desire Z mobile phone and then reassembling it. Third time, I noticed that the problem is due to looseness of two, out of three, tiny screws at the "camera" button of the mobile set. Therefore, mobile set was not properly pressed and sealed at the "Camera" button and due to some protection by HTC, screen went black. Now I have used new relatively long tiny screws and the problem is solved permanently.
Htc evo makes crackling noises and vibrates lights up but wont turn on all the way
you either have a defective battery or a mainboard fault inside the phone.
Hi,my wildfire screen will not turn on,the home,back,menu buttons and led light up but the screen wont light up or do anything. have u any ideas ? thanks
Hi
if everything light up except the screen that means your screen is either loose(if you drop the phone) or you need to change lcd as it got damage.
3helpful
How to fix or escape from htc touch align screen
The quickest way out of the alignment screen is to actually align the screen by pressing the screen whereever the little cross is located on the screen. Or if you don't want to align the screen simpley hit the power button to turn it off and then hit it again to turn it back on.
Top Verizon Communications Cell Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
