20 Most Recent Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Questions & Answers
0answers
No caller id on Blackberry 8800 when using bluetooth headset
yes it will happen when u connect with your Bluetooth you have to use your Bluetooth only no u can see anything on your phone
5/20/2017 9:24:21 AM • Verizon... • Answered on May 20, 2017
4answers
I bought a used blackberry
If you log in ten times with the wrong password the Blackberry will reset to the factory settings. This will earse all the data and unlock the phone.
10/17/2012 5:46:29 AM • Verizon... • Answered on Oct 17, 2012
0answers
How can i change my voicmail password?
You would have to call your sevice provider and they can help with that or if you log in to your acct. online you should be able to do it there good luck
2/15/2012 9:15:12 PM • Verizon... • Answered on Feb 15, 2012
How do i activate my verizon phone if i am not the
you can contact the mobile service provider.....
8/31/2011 7:17:51 AM • Verizon... • Answered on Aug 31, 2011
5answers
Is there an unlock code for the verison blackberry
Its not possible that you can get free code its comes from server based on your IMEI.
Yes you can use as normal GSM phone after unlocking.
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
***SPECIAL CHEAPEST PRICE till 31th July from one of oldest provider.***
After unlocking from this provider's code your blackberry not only work with any network, you can use your Blackberry in any part of world with any GSM networks including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry & remove restrictions like AT&T or any
This site will help you a lot & good email & 24/7 phone support.
http://blackberryimeiunlockcodes.com/
5/7/2011 11:11:22 AM • Verizon... • Answered on May 07, 2011
My phone suddenly has no
Contact your cellular service provider and ask for Tech Support. Tell them what problem you have. Ask if they will walk you through the directions to perform a 'Hard Re-Set' on your phone. (This is something that needs to be done while they can talk to you.)
If this doesn't work, ask them for assistance in getting you a new phone. They'll be glad to help.
1/24/2011 6:19:55 AM • Verizon... • Answered on Jan 24, 2011
My blackberry keep say jvm error 102 reset
To resolve your problem, connect the handheld to the desktop computer and start the Application Loader.
Re-install the BlackBerry Handheld software.
If you don't have the software, go here: http://www.blackberry.com/btsc
Select downloads, then BlackBerry® Device Software and BlackBerry® Desktop Software. Follow the steps from there and you should be ok.
12/25/2010 4:39:50 PM • Verizon... • Answered on Dec 25, 2010
2answers
Can not find/get EMEI number. How
GSM phones have IMEI numbers...CDMA phones have an ESN number.
To locate the personal identification number (PIN), International Mobile Equipment Identity (IMEI) number, electronic serial number (ESN), or Mobile Equipment Identifier (MEID) number on your BlackBerry smartphone, complete the following steps:
  1. On the BlackBerry smartphone Home screen, click Options.
  2. Click Status.
If you do have the gsm version.
This number can be obtained by pressing the key combination *#06# (star pound 0 6 pound) while the phone is turned on. When the IMEI number displays on the screen of your phone, write the number down.
11/29/2010 8:09:41 PM • Verizon... • Answered on Nov 29, 2010
Cannot receive calls on my
Hello parks willia If your having trouble with the pearl look athe radio connection on the phone. Make sure it isn't off.
If you see it in the off postion you need to go the radio connections on your blackberry and turn it on. If that doesn't work the quickest fix is to put the battery and put it back in the phone. Now then other thing you should do once it boots up is the *228 option 1 and let the phone reprogram. I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
11/26/2010 4:28:27 AM • Verizon... • Answered on Nov 26, 2010
5answers
Blackberry pearl troubleshooting
My phone does the same and i realized that it seems to have something to do with the yahoo messanger and the facebook mobile apps i have installed. It improved once i deleted any such messaging application even though the problem did not dissappear completely.
11/16/2010 12:08:08 AM • Verizon... • Answered on Nov 16, 2010
2answers
I have a blackberry 8130 flashed to Cricket and I
Contact your service provide and ask them to send the internet information to your phone
10/19/2010 6:28:01 AM • Verizon... • Answered on Oct 19, 2010
3answers
Im trying to unlock a blackberry 8130 verizon
Hi, We can unlock your Blackberry in 30 Mins. No Need Cable.
Just Give me your IMEI Number, Network name and Pay $6.00 .
We will Send unlock Code/MEP Code. Just Enter Code. Your mobile Will be Unlocked.
100% Working. 100% Money Back if not unlocked. email to [email protected]
10/12/2010 1:58:05 PM • Verizon... • Answered on Oct 12, 2010
Have a blackberry pearl 8130
Keep push button with red phone (turn the phone to you, its the first up button on the right) until turns on...
9/18/2010 12:52:44 PM • Verizon... • Answered on Sep 18, 2010
2answers
My Pearl was recently reactivated.
check your call forwarding is not activate
Forward calls
Verify that you have one or more call forwarding numbers.
1. In the phone, press the Menu key.
2. Click Options.
3. Click Call Forwarding.
4. Press the Menu key.
5. Click a call forwarding number.
6. Press the Menu key.
7. Click Save.
To stop forwarding calls, change the Forward All Calls field to Do Not Forward.
also scroll to the speaker icon and make sure it's not on off or similar.
robert
8/24/2010 4:43:03 AM • Verizon... • Answered on Aug 24, 2010
6answers
Not receiving text messages
You are running out of memory, just free up your memory. You can do this by doing some or all of the following:
  • Clear your log (hold alt and press lglg>then menu key>select "Clear Log">confirm)
  • Close programs you're not currently using (hold alt and back button) Some items will always be running like messages, phone, browser, home screen so on and so forth, leave those running
  • Uninstall themes and programs that you are not using anymore (Options>Advanced Options>Applications) [Leave the following applications on the phone or you will have trouble: BlackBerry "Version # i.e. 4.2" Core Applications; BlackBerry System Software; BlackBerry Attachment Service; Browser; Help; Phone. The rest are if you use them or not i.e. Tasks; MemoPad, BB Messenger, if you don't use them then you can delete them without major problems on your phone)
  • Move photos, music, video and other multimedia over to your disc instead on the actual BB device. Also delete ringtones that you no longer use
  • From your desktop uninstall languages that you do not need
  • Delete out your old text messages and emails, try to save them on your computer instead of your laptop (with email) or forward text messages that you need to your email then delete the actual text message
This should be a good start to clearing out your memory and start receiving text messages again along with your call logs showing up. If you remove an application it will ask to reboot, let it and then send a text message from online to make sure that you're up and working again. Then maintenance your BlackBerry about every week afterwards depending on your storing habits. Hope it works!
7/23/2010 12:45:05 AM • Verizon... • Answered on Jul 23, 2010
2answers
Unlock blackberry pearl
It is possible to unlock your Verizon BlackBerry Pearl. Infact I got my Curve 8310 unlocked last week.
Here is the link that I used to purchase my unlock code.
Unlock code came in via email, along with the instructions on how to key in the code, and within 30 seconds my BB was unlocked.!
Or you can call your provider to request an unlock code for free, if you are with them for more then 90 days, they will send you the code with in 1 - 3 weeks.
7/15/2010 12:15:07 AM • Verizon... • Answered on Jul 15, 2010
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
Popular Tags
145 questions posted
Top Verizon Communications Cell Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Verizon Communications Cell Phones
Most Popular Question
phone suddenly no
  • Cell Phones
