Avaya 5400 Series 5410 Phone Logo
Posted on Jul 27, 2010
AVAYA 5410- want to turn Caller- id off
Hi
Our phone is AVAYA 5410
Our company wants to block all caller id displays for everyone..
how to shut caller id off??
Thanks in advance
A
Anonymous
Do you have access to Manager? You can tag the incoming call which does not show the caller ID of a call until the call is answered.
1helpful
Can we have caller ID on the 3158-05
The Avaya 3158-05 does not have a display. It can't show the Caller ID information from the telephone provider. The Avaya 3158-07 PARTNER 18D or the 34D will display Caller ID information if your system is connected to a telephone line. (One of these modules: 206EC, 308EC, or 400EC, is required. If you have a T1 line, you can't get Caller ID.)
I hope this helps.
2answers
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Hi is there a way I can check caller id on my phone
That is a feature sold by your local telephone company. It cost a few bucks to have it added to your telephone line, then your phone has to have the ability to display caller ID. if your phone does not have that ability, then you can buy a display device that plugs into your line and displays it, It will only display those callers that do not block their lines from being IDed.
If I turn off the ringer does this also turn off caller ID?
Turning off the ringer won't affect the caller ID display. All that happens when you turn off the ringer is that the phone doesn't make noise any more. The ringing signal and caller ID information from the phone company still will reach the phone.
Caller Id blocking
There are no lines available. Have someone test dialtone on all your lines.
Caller ID not displayed
check the settings on the PBX , Caller ID has to be set -up correctly on the PBX , ie T1 needs to be configured to pass the caller ID to the PBX and to the phone
Caller ID
No. That phone is not caller ID compatible.
Caller Id not working, phone disconnects after 2nd ring
This problem turned out to be a phone company problem.
Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Top Avaya Lands Phones Experts
NOEL
NOEL
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
