20 Most Recent
Avaya Definity 6408D Corded Phone Questions & Answers
Number of rings
Sounds like you have either send all calls (SAC) enabled or your station is call forwarded to voicemail.
Disabling send all calls or call forward (as applicable) will solve the problem.
Change ringtone
With the handset on the hook press the conf button (the one with three phones on it).
The phone should ring with your current ringtone. Each press of the conf button will advance to the next tone.
pick up the handset and put it down again to select the ringtone.
I think there are 8 to choose from.
Change extension numbers
From the phone dial #66xxx (where xxx is the extension) to turn off that phone.
Then dial *66xxx (with the correct extension) to turn on that phone.
Hope this helps.
I have a AVAYA 6408
You activated that feature yourself by hitting *3 you may want to use this when you go on vation so it goes directly to VM. #3 will deactivate this feature.
Message indicator light
Check message lamp extension for the station in communication manager
check Voice mail system is sending the message waiting indicator
if all phones also check any trunks to the voicemail system
Want to disable outgoing calls on avaya 6408d
well.. we use a definity and i use site administration and on the station account its self i have a COR setup to restrict the phone from dialing out. if you want help and have the same system let me know.
Changing name on display
You have a Definity system, unfortunately, these are very high end systems, and you will need to contact your system administrator as it needs to be changed via the computer that runs your system.
Change time on phone
Phone system console. Contact your system admin, as it depends on exactly which system you have.
