I found these wire colors. Anything get your attention? I usually want to check voltage and ground. What if that wire color is gray, that is serial data and yes it will cause problems. I wish you could have drawn an arrow to the particular wire? Very good picture.
I suggest check the cables first. The color changes are almost always a faulty wire in the cable. Try working the cable back and forth near both connectors. If this causes the color change you could have a broken wore in the cable, or a loose pin in one of the connectors.
yellow wire power full time red wire power with key on only black wire ground blue wire power antenna or amp (orange which isnt always there is dimmer) other four sets of colors are speaker wires
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset:
? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound
? Channel Memory
? Audio to Stereo
? Caption to OFF
? V-Guide to OFF
? Aspect Ratio to 4:3 (normal)
? Menu Language to English ? Sleep Timer (if previously set)
? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
