my rav 385 remote everything works except turning up the volume how can i fix that problemmy rav 385 remote everything works except turning up the volume how can i fix that problem
You can't post conmments that contain an email address.
Try Total Control Remotes - www.totalcontrolremotes.com. They are expert programmers and program remotes and control systems anywhere in the USA.Try Total Control Remotes - www.totalcontrolremotes.com. They are expert programmers and program remotes and control systems anywhere in the USA.
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
Would
you like to program the Universal Remote that came with your Dish Solo
DVR VIP 612 to control the volume of your receiver, tuner, or stereo
instead of your TV's volume?
The
first step in using the Universal Remote Control that came with your
Dish Solo DVR VIP 612 to control the volume level of your receiver,
tuner, or stereo is to program the remote to control your audio device
using the AUX mode button.
Once
your remote controls your audio device in AUX mode, you probably want to continue to control the
volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish
Solo DVR VIP 612 Universal Remote to control the volume of your stereo
regardless of which mode it is in, follow these steps:
Press and hold the AUX
button until all the mode buttons are lit, and then let it go.
Press the POUND (#) button.
Press the PLUS side
of the VOLUME button.
Press 0.
Press the POUND (#) button. The AUX button flashes three times to tell
you the programming is complete.
Confirm the VOLUME buttons
are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's
volume should change rather than your TV's volume.
Your
Dish Solo DVR VIP 612 Universal Remote is now setup to control the
volume of your stereo regardless of which mode it is in
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
Press and hold the AUX button until all the mode buttons are lit, and then let it go.
Press the PLUS side of the VOLUME button.
Press 0.
Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process.
Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com)
Using Pre-Programmed 3-digit Code method
-Turn on soundbar
- Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit.
- Point remote control toward the soundbar and enter code (447 for Boston Acoustics)
- Press the device button again to store the code.
The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me.
Step 2: Program your remote from the Boston Soundbar.
- Press the power button and the volume up button simultaneously until the indicator light flashes orange.
Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming.
- Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange.
- While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed.
- Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote.
Good luck, I hope this helps. -Deidre.
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
