Acer Aspire 5610-4648 Notebook Logo
Posted on Apr 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HI have a ACER HL-DT-ST-DVDRAM GSA-T10N ATA DVD DRIVE AND THE DVD DRIVE OLNY LOAS SOME PROGRAMS ON DVD DISK AND NOT OTHERS AND ALSO WILL NOT WRITE TO THE DVD OR CD DISK
Richard Roberts
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 198 Answers
  • Posted on Apr 22, 2008
Richard Roberts
Expert
Level 2:
Mentor:
Answers
198
Questions
Helped
151922
Points
324
The cd-dvd drives will only work if you have a good non-microsoft burning program. Your computer came with such programs--one or two. find out by installing a freeware program called Belarc advisor. It will show you all hardware and software with ids and version numbers. You didn't mention if your computer was an Acer. If it is, you have a copy of all the software saved on the hard drive. or did you purchase the DVD drive separately? if Acer, you can find and reinstall your original program using Acer eRecovery Management. (You can read about your Acer by clicking on "All Programs" and then on "AcerSystem", where you will find your manual, where you will find the following info: The eRecovery allows you to backup/restore the factory default image, and reinstall any applications and drivers. (In this instance you want to reinstall your CD-DVD burning programs). You just need to select the Burn Disc button, then select the application you want to burn to the disc--in this case, you CD-DVD buring program you identified with Belarc, burn it, then reinstall it. (You might want to burn all the applications the computer came with, just to have them for backup). That should get you going again. Let me know if you run into any problems.
2answers
My Cd-Rom doesnt work for my Acer Notebook 2930
Got to the Acer Web site and look under drivers and downloads. Select your model # and download the corresponding drive. Your prblem should be fix
Hello. I'm a user of Aspire 4520.My Hl-Dt-St Dvdram Gsa-T20n Ata Device had changed to Hl-Dt%St Dvdrae Gsa-T20n Ata Device . It's starting to happened after i using windows 7. There is no upper/lower...
Put the "System Restore" disk into the drive,
and restart your computer.
Choose to "change boot order" so that the first boot-device is your CD/DVD unit.
Your computer *WILL* boot from the disk in the drive,
allowing you to reinstall Windows.
HL-DT-ST DVDRAM GSA-H62N ATA doesn't read DL after being burned
this may happen as your DVD reader's lance may got weak. plz check for the same and replace lance if problem exist.
3helpful
HL-DT-ST DVDRAM GSA-T20L ATA Device Code 19 My
sure ...just look for the driver on your laptop site ..and reinstall it ...this should fix the problem ..if not ...restoring the OS or reinstalling it will fix it too
2answers
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
MY LAPTOP DOES NOT RECOGNIZE MY DVD/CD DRIVER... CODE 39
you need to do
1) confirm the dvd driver works ok at other same laptop or find a usb dvd drive adapter to check it works well or not, the dvd driver damage if not
2) check the dvd interface pins (no damage or disconnection) on the motherboard, there is hardware problem that you can not see or heard any lights and driving sounds when the power on
1helpful
4answers
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
