SOURCE: Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE
**8463 – Display shows PASSWORD:
Then type in 23646
(Note this number will not show on display)
The display will show
hours.
Press CHANGE
(or NEXT if you do not need to change the hour).
Enter the hour (00 to 23).
If number is less than 13, the display shows AM.
Press CHANGE
to select PM.
Press NEXT.
The display shows minutes.
Press CHANGE
(or NEXT if you do not need to change the minutes).
Enter the minutes (00 to
59).
Press NEXT.
The display shows year.
Press CHANGE
(or NEXT if you do not need to change the year).
Enter the last two digits
of current year.
Press NEXT.
The display shows month.
Press CHANGE
(or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT.
The display shows day.
Press CHANGE.
Enter the day of the month
(10 to 31)
Press
RLS (release) to exit.
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password
Retry
Step 2
Press 266344
on the dial pad buttons to enter the DEFAULT password. Your password
MAY BE DIFFERENT! The display will show the following options:
Hour: 01
Next
Change
Step 3
Select CHANGE - the display will show the following options:
Hour: __
Cancl
Step 4
Use the dial pad buttons to enter the hour. You must use two digits for
all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM
or PM. Select CHANGE and OK to choose PM.
AM
OK
Change
Step 5
After you have entered the hours, select NEXT. The display will show
minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the
RELEASE (RLS) button to end your session. The time will be changed and
the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00
Next
Change
Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99
Next
Change
Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
SOURCE: How to change the time and date on nortel phone
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Is the T 7316e going in the same place that the T7316 came from?
