Samsung SCH-a870 Cellular Phone Logo
Posted on Apr 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display screen is backwards
I dropped my phone in a rye&coke, dried it out, worked great after that. I later dropped it in a glass of water, worked great for a short time, and now my display screen is backwards. I have to use a mirror to read my text messages. Is the phone toast?
  • Lutzy105 Apr 19, 2008
    LOL.. rye&coke is my preference as well. It's been about 2 weeks since it had a bath in water, a short time after I dried the phone out and got it working is when the screen started inverting everything. Typically I would power it off or pull the battery and it would work again. Now it doesn't seem to want to recover from it. Anyway I appreciate the help, and I let it sit for a few days.
Anonymous
Level 3:
  • Master 472 Answers
  • Posted on Apr 19, 2008
Anonymous
Master
Level 3:
Answers
472
Questions
Helped
190965
Points
1152
Sounds like the LCD is missing a signal getting to it. One of the signal lines is either damaged, possibly still has a small amount of liquid on it and is getting a bunch of resistance it shouldn't be.
Open the phone up, and let it sit and dry fully for a few days.
You could always try dropping it back into the rye & coke, it seemed to prefer that to water =0)
  • Anonymous Apr 19, 2008
    By the sounds of it, if only this phone could talk.. The tales it could tell of its many adventures, both above and below sea level =)
    If it makes you feel better, I had to fix a phone damaged like this, not once, not twice, but 4 times. The "lady" in question kept dropping into into the toilet at nighclubs. Gloves on for that job =)
How do I repair a Telus Digital PRV box which had liquid (rye & coke) spilled on it?
the sugars in the coke & rye are going to eat the etchings on your PCBs. you will need to unplug unit, take back off & look at all circuitry to see where substance went. Clean it all off ( recommend using cotton swab & alcohol, not the Rye)
as you're cleaning look for any places where the etching is eaten through & you might try to bridge that circuitry,but as small as some of these are you will most likely have to replace the PCB. also once the corrosion starts you are not going to stop it. decide how many circuit boards & cables need to be replaced. You may find that it is not going to be cost effective.
I dropped my phone into coke how to dry it?
Your phone is not likely to ever work again. You can do the standard stuff ...bowl of rice etc, but dont expect much in the way of good results. Coke is very corrosive.
My cell phone was dropped in a glass of coke and minutes later the keypad in number sign, zero, and asterisk are no longer working. how can i fix it?
never use the phone after water is enter into the phone.. Its damage the phone more. Remove the battery.. Go to your nearest servicing station.
LG Shine CU720's screen does not work.
sorry to say i think its toast but you can try taking out the battery and phone card cuz i droped mine in a glass of water and i had problems witht the screen at first but then i left it dry out also try putting the pieces in a bag of rice to dry it out but if it still doesnt work i think your just out of luck because the companies warnity doesnt cover water damage.
Wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
May 31, 2009 • Cell Phones
3answers
Pantech Duo dropped in Coke
AT&T isn't going to fix it.
If you recently got it I suggest you buy a warranty and wait a week and then get it fixed threw the warranty.
Mar 15, 2008 • LG VX6000
Samsung T809, screen display is dull(week)
unfortunately, the board of your mobile phone has corroded. When the water dried up rust was developed. try cleaning the board of your phone...
4answers
Paul skurulis
you needed to open your phone and to dry it throughly or have it check to technicians maybe thier is still moisture left inside and causes your phone to malfunction.
Phone LCD is very dull after water damage, rest of phone works
go get a torx screw driver and open it up stop turning it on that will only hurt it ... once you open it up dry under a lamp for a day and it will probably work
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
