Was running perfectly, now when you try to operate it, it stops and you get a constant beep-beep-beep, like something is unplugged or disengaged??
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
