Heating & Cooling Logo
Posted on Jun 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ur condenser won't stay on in the late afternoon. It works in the morning but in the heat of the day it only kicks on for about a minute then shuts off but the fan still blows. Do you think it's the progamable thermostat being defective our the condenser?
Anonymous
Level 3:
  • Master 1,515 Answers
  • Posted on Jun 28, 2010
Anonymous
Master
Level 3:
Answers
1515
Questions
Helped
629082
Points
4388
Hi, its the condenser unit going off on high head pressure. As the outdoor temperature rises, so does the freon pressures also, which cause a very high load on your compressor. Pressure and temperature relationships are very important in the way your unit operates. To solve this problem, cut off power to the outdoor unit. Take your garden hose and give your wrap around coil a good washing of dirt and dust build up. This keeps the head pressure to a normal level so the compressor will not shut off on overload. Be careful not to bend the aluminum fins on the coil with to much pressure. This is also important so the fan can pull air through the coil and out the top to remove heat from indoors to cool your home. Yes, the fan will continue to run when this happens, and its job also is to keep the head pressure down to a minimum, so be sure it its running good and strong. This will take care of the problem unless you have a restriction internally, I don't believe that's the case, just a dirty plugged condenser coil. A tip for you to remember, when the outside air temperature rises, so does the freon pressures in any unit that runs on freon, your auto, refer, and so on, so if something like a coil that is plugged with dirt and will not let the fan pull air through it to keep it cool, it will shut the compressor off on its overload protector to keep it from burning out. A safety switch. Please let me know the outcome. Good Luck,
Shastalaker7
It is silent over night bur as soon as the door is opened in the morning the motor kicks in and it starts buzzing. this goes on all day.
NOT SURE THIS IS UR PROBLEM BUT THOUGHT ID SEND IT
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE
1helpful
1996 honda accord ex (six cylinder) My engine temperature gauge will go to the halfway mark and sometimes just a small way past this half point mark. It only does this in the mid to late afternoon...
if overheats,and trows water or steam,there you can think on the water pump or the thermostat,but you only have a signal problem,try replacing the tempeture sensor.
My intertherm central ac is running short cycles
Hi!!
It most likely mean that the condenser needs to be cleaned up.
At hardware stores and A/C shops, they sell a cleaner for it, get the ECO frienly version. Instruccions are in the bottle.
If condenser looks clean, (that you can see thru it), then check fan motor, it could be going bad not giving the right RPMs. When this happens, it overheats.
If the condenser can't get rid of the heat the evaporator picks up, the compressor overheats and the thermal proteccion device kicks in to protect it from getting damaged..
Don't forget to rate this post!! Good Luck!!
The air conditioner kicks off every few minutes on very hot days
Check the condenser coil, it sounds like it's dirty. If not then the condenser motor may be bad, running slow or not running at all.
1helpful
Garmin Edge 305 will power off in a min or 2 riding in afternoon
This is a generic problem with the 205 and the 305 go to MTBGurublog and look up 305 problems there is a blog that shows how to open and fix it
Fan kicking in too often 1998 f150 4x4 4.6 tow
If the engine is not over heating then it is doing its job. The constant cycling is based on the temp of the air traveling through the radiator and the a/c condenser not the outside temp so much. The start up high rev is just how these clutches work in ford fans. It sounds like it is operating correctly.
1helpful
A/c works fine in the morning but in the afternoon it works fine until i stop or change speeds. If i turn a/c off and wait about two minutes it works fine again until i stop or change speeds
3 things to check here. 1 make sure there is sufficient amount of freeon in ur system. 2 make sure your ac cooling fan comes on . must come on to help cool the condenser. 3 make sure that you dont have any debri stuck in the condenser or between condenser and the radiator....that has been a problem around here that as a technition i have seen many times---hope this helped you
Running long time
hi thanks for the question. yes if that's the temp that you say 36 to 38 degrees is normal operating temp thanks the appliance doc
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
Top Heating & Cooling Experts
Paul Carew
john h
