I am assuming by the timber of this question, that the mower you have is a Sears Craftsman mower of some description. go to the Sears website and search manuals online....they have many manuals that can be viewed and downloaded and you might just luck out and find the one you need. Also search the mower over carefully....look on the engine shroud and also the rear of the mower.....some of the older ones had the model no. stamped into the sheet metal. If all else fails, take a piece of 1/2 inch rope and thread it through the tensioner and the pulleys and mark it when the two ends meet...then measure from the end of the rope to your mark...et viola...the belt length !!! The length should be real close...when using the rope keep it fairly tight around the tensioner and pulleys...hope this helps... ;-D
What you ask is impossible. You need the model number ... you don't have it ... neither will anyone else.
The best thing for you to do is take what you have to the auto parts store and see if they can match it at all.
You should probably measure the distance around all the pulleys and tensioner to get some idea of the length. If the store will cooperate, you should get a couple belts to try and return the ones that are not corrrect.
