On most Mitsubishi's there is a button on the front panel (behind the door) that will allow a A/V reset to factory specifications.
With your particular model there are to modes of reset. The first one doesn't do a complete reset, try that one first. On the front panel behind the little door there will be a button that says: "System Reset" it's recessed to you need a pencil or a pen to push it. Push it, let the green light flash for up to a minute and then turn your set back on. If that doesn't cure your difficulties then you can use a hard reset (like rebooting your computer) by pressing the Guide Button and the Format button at the same time and it will reset itself to original default factory settings.
Zashiban
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
