Sharp AR-5316 Advanced Digital Imager Copier Logo
Anonymous Posted on Jun 21, 2010
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jul 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
4965
Points
14
Copy lamp problem.... ccd connection.... dirty optics; use simulation 05-03
  • Anonymous Jul 08, 2010
    if it is h & 2, clear it by sim14; if repeated, chek thermistor
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
337
Points
Dear sirs,
my copier (ar-5316e) while copying shows "2" and then "h" but not copying how can i solve this matter. plz solve this matter as soon as you can please please please please please.
Eqbal, Kabul , Afghanistan
  • Anonymous Jun 28, 2010
    please solve it soon
amir hamza
Level 2:
  • Sharp Expert 318 Answers
  • Posted on Jun 21, 2010
amir hamza
Sharp Expert
Level 2:
Answers
318
Questions
Helped
188813
Points
694
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
1 Related Answer
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jul 31, 2010
SOURCE: Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Testimonial: "than u sir every time i had problem u are helping me sir thank you so much sir"
107helpful
10answers
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
65helpful
6answers
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
I Have Sharp Photo Copier AR 5316 when i given Print command the image was good but background double image was also come pls sir give some urgent tips sir
Needs a fuser hot roll. Once the get worn, they pick up some of the image and reprint it on the page.
They are available form several sources, Kaytin comes to mind. Precision roller. Google the printer model number . I would google is like this. Sharp AR 5316 hot roll.
That should give you several sources, Honestly I would replace the press roll also. Probably you should be able to find them both for less than 100 dollars, I sure wouldnt pay more. Look around. You can find them for a decent price. You may even want to look on E-bay. they often have them there.
1helpful
MCU PWB abnormality
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
4helpful
4answers
SHARP AR 5020 error F5-02
you reset your eror code program c#0#
3helpful
2answers
SHARP AR5320 error F5-02
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
DOS PRINTING DRIVER
you need a dos printing software that will print in Windows
try these
http://www.printfil.com/english.htm?gclid=CKGbrPGd_pQCFQIyxwodyzo6cA
www.freedownloadscenter.com/Best/dos-printing.html
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
