Luminox 3402 Wrist Watch Logo
Posted on Jun 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water under lens
Water gets under the lens
Anonymous
Level 3:
  • Master 623 Answers
  • Posted on Jun 21, 2010
Anonymous
Master
Level 3:
Answers
623
Questions
0
Helped
243377
Points
1441
The water resistant seal(s) in the watch case have been compromised. There is not much you can do except find a competent watch repair shop and ask them to look at it, clean it, dry it, oil it and change the seals. You might try using a desiccant in an air tight box like a Tupperware food storage container, and place the watch in the box for a day or so to see if the desiccant will pull the moisture out.
1helpful
Why watch get foggy after go in water
Moisture is getting into the case under the crystal. A jewelry store might be able to tighten the case or replace a gasket. It would be better not to wear it in the water unless this is repaired.
1helpful
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
WHEN EVER IT GET HUMID MY MOVADO HAS WATER BUBBLES INSIDE THE CRYSTAL. IT TAKES DAYS FOR THE WATER BUBBLES TO CLEAR?
mcdevito75 here, This is condensation, the difference in air temperature inside and outside your Movado watch, no watch is air proof, Humid means water in the air, the higher the humidity the more water is in the air. As the humid air enters your Movado it cools thus leaveing water behind, very much like boiling water, we see the steam, but put a cover over it and we see water, the hot air hitting the cover cools and turns back to water. However in your Movado this is too much and over time your watch will become water logged and be no good, Best Bet, look for a small watch repair shop in your area and have them re-seal the crystal and back cover of your Movado watch, also chek if your watch is still under warrantee, if so the re-seal should be free.
Oil all over wrist watch - can it be cleaned?
hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 • Watches
Moisture under lense
Moisture can sometimes be removed by putting your watch in a warm place and leaving there for a day or so.
If it persists, then it may be necessary to remove the back of the watch. This is usually best left to a jeweler, especially if it is a waterproof type, as the seals can be difficult to re-fit. If your watch is still under warranty, then you may invalidate the warranty if you try any self repairs.
Jan 12, 2010 • Watches
1helpful
Water under crystal
Obviously you have moisture inside the watch. If the crystal is not cracked then moisture can get in around the stem if the seal is no longer good. Although also possible is from a bad seal on the case back. These seals need to be replace every 3 to 4 years and then properly lubricated with a special silicon grease. With time, the seals will tend to flatten out and the grease will dry out. So get it serviced before the moisture will permanently damage it. Also. 330 ft is if you decend slowly. If you jump in a pool or subject it to a heavy spray, like in a shower, that is another story and they don't always keep the water out then.
Dec 12, 2009 • Watches
How do i change my timex from military time
The owner's manual that was sold with it should guide you. If it's missing, get a good hand-lens. Take the watch under a good source of light, and aim the hand-lens to the edges of the watch. You should see 12/24hr button. Press the button once. The time should change from military. If it doesn't , press and hold the shortest button for about 5-seconds. Then press the button that is marked 12/24HR.
Lens has been scrached
Unless you have an acrylic lens you will not be able to buff out the scratch.
I recommend getting the lens replaced with a sapphire scratch resistant crystal. This will be a little more expensive but well worth it as far as maintaining the aesthetic beauty of your time piece.
For a great repair house you can see the box titled top watch repair on this page or look in your local directory.
My problem is my Citzen Eco Drive works but the WR100 seems to be off. I under the theory of WR as opposed to water proof but, should it really be getting foggy under the crystal after i wash my hand? On a...
These water proof watches are only water proof if the knob for setting the time is pushed all the way in. Try to call your Citizen dealer, if you read them the numbers on the back yhey can see if there is warranty to check the problem for free.
If you need to know more about your Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Top Luminox Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Luminox Watch Expert? Answer questions, earn points and help others
