Invacare Pronto M51 Power Wheelchair Logo
Posted on Jun 18, 2010
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
918
Points
On my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jun 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
18171
Points
53
Yes. The light on the charger will turn green when fully charged.
Are both lights supposed to be green i have 1 red 1 green on my battery for my invacare scooter
Mine is an Invacare M51 Pronto Surestep with an onboard Winsunny battery charger. My charging lights are solid red and green/ yellow. Depending on if it is charging or not. What kind of charger do you have?
I have to replace my charger because it is not working. My green light is staying green while charging even though my joystick is showing my batteries are depleting and I just got new batteries. sigh.
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
8helpful
2answers
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
The yellow light means that there still is an amount of charge on the battery, meaning that it isn't fully discharged. The red light means that it is partly discharged and you can charge it up.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 23, 2011 • Garden
1helpful
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
2helpful
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
1helpful
There is a yellow blinking light on my Black jack
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
