20 Most Recent RIM BlackBerry Pearl Flip 8220 Cellular Phone Questions & Answers
To use Answer button on the BlackBerry smartphone, complete the following steps:
1) On the Handheld press Call button.
2) Press the Menu key.
3) Select Options.
4) Select General option.
5) Select Auto answer calls to, (Never).
6) Select Auto end calls to, Into holster.
7) Click on save.
I hope I was able to help you.
Thank you for using Fixya.
RIM BlackBerry... | Answered on Nov 29, 2018
Don't worry about it. it is very simple to Unlock your Blackberry 8220 Pearl Flip by entering Imei Unlock Code . you can get your Mep Unlock Code for Blackberry 8220 Pearl Flip by third party or your network provider.third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy Blackberry Imei Unlock Code from third party. they will charge little amount.i hope this will help you.
RIM BlackBerry... | Answered on Jan 10, 2018
Try updating to the latest software and clean the SIM contacts by removing and re fitting the SIM.
RIM BlackBerry... | Answered on Jun 10, 2017
If you did not pre-install tracking software on your blackberry than there is no way to track it. The cell phone company can track it, but it is not worth their time and cost. The police of course can also track it but probably will not, sorry to give you bad news. Best bet is to go directly to your supervisor who will have the phone cancelled and wiped before any important business information is stolen and used by the thief.
RIM BlackBerry... | Answered on Sep 09, 2016
Try to replace battery,might only be the problem,otherwise need to update the firmware due to software crash.
Here's a procedure on how to fix your phone.
FOLLOW ME
Thank you for visiting FixYa...
RIM BlackBerry... | Answered on Aug 30, 2016
Unless it is a CDMA phone, it should be under the battery.
I hope this helped.
This may be needed:
https://www.wireless.att.com/support_static_files/KB/PATTLNK_1122006_1753-8100c_SIMcard.jpg
RIM BlackBerry... | Answered on May 24, 2014
If your Blackberry 8220 phone displays an error message saying "Sim card error" then your phone is probably sim locked.To unlock it,visit the site Unlocking4U.com here they are providing the permanent sim unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.This is the easy and fast unlocking method.
Source:http://www.unlocking4u.com/blackberry-8220/rs5wp9/
RIM BlackBerry... | Answered on Jan 10, 2014
By retrieve do you mean you have already recevied them and they are no longer visible to you?! If so check the following.
You may have already tried some of these options, but for the sake of completeness.
Check your icons are not hidden. From desktop/ Options/ Show All.
The MMS Data - MultiMedia Messages may be stored along with
your Text messages - check this folder.
Check all your Media folders - including My Pictures and Preloaded.
Failing all of the above - Check MMS in Options and MMS and do the same for Media Card.
If you connect your Blackberry to your PC you will be able to see all stored files and their location..
If you are not able to receive them in the first instance - You will need to enable yout Blackberry to receive them by MMS in Options and checking this option in addition your Network Provider will need to send you settings to store.
RIM BlackBerry... | Answered on Nov 15, 2013
A) Perform a hard reset on the BlackBerry smartphone.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry
smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
B) If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
C) If the battery is working, download the latest BlackBerry® Device Software and install it using the application loader tool in BlackBerry® Desktop Manager
RIM BlackBerry... | Answered on Nov 11, 2013
Try dipping your finger in rubbing alcohol then, applying a little pressure, try to roll the ball around. This issue is common on these phone. Usually the pressure and alcohol help free any debris that may be causing the ball to stick. If that doesn't work the ball may need to be removed to clean out any debris that may be in there. A quick google search can show you how to remove the trackball easily.
Hope that helps.
RIM BlackBerry... | Answered on Sep 19, 2013
Okay for the PC Suite, connect the device to either Windows Vista or 7, and then download and install Desktop Software 7.1 from BlackBerry.com, here is the link: http://us.blackberry.com/software/desktop/desktop-pc.html Once downloaded and installed on Desktop Software you can do backups of the device, synch music and photos over to the computer or items on your pc back to the phone such as pictures stored on computer, you can also do regular software updates from Desktop Software.
RIM BlackBerry... | Answered on Jul 29, 2013
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
1) Remove the battery cover from the back of the BlackBerry smartphone.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
RIM BlackBerry... | Answered on Jun 12, 2013
No guarantee, but try --
You must OWN your BlackBerry out right. Have your IMEI# available. If applicable, on your BlackBerry, dial *#06# to retrieve your IMEI#. Contact your service provider. Ask for a BlackBerry Data Support Representative. Explain why you need Unlock Code (ie: need to use your phone out of the country).
Good luck! ~ :)
RIM BlackBerry... | Answered on Feb 27, 2013
Dear brother:
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
RIM BlackBerry... | Answered on Dec 22, 2012
To unlock Blackberry,visit Mobileunlocksolutions.com for which you have to provide which country you are,network in which it is currently locked.Then they deliver you the code to unlock your mobile and they also provide free instruction guide about how to unlock your mobile.
RIM BlackBerry... | Answered on Dec 15, 2012
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
516 questions posted
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
reload software 507
  • Cell Phones
