It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
try the calibration screen in the options menu and follow the directions...make sure you hold the screen over the X until it moves to the next position.
if that fails, you might need a digitizer...let me know and ill help you further
i fix these and many other magellan
gps daily so when considering
my advice , please understand i do not google my solutions.
As the touch screen is not working,then you only need to replace a new working touch screen for Megallan RoadMate 1412,you can try to contact:
MSN/EMAIL:[email protected]
SKYPE:keyudakim
Probably she will give you a good solution for that touch screen.
good luck
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
Try resetting it with the reset button on the side just above the plug in. Mine did the same thing when I used it the first time. If it continues I will return it.
