We need help installing an Aspire slide dimmer. the ground wire is clearly marked, and the other three wires are colored black, gray... which is the positive, and white. we do not know which wires go...
There are several variables here and you haven't completely described your situation, but I will give you two scenarios. But first, understand that if your switch has three wires, then it's a three way switch, and maybe you don't need a three way switch - but you can use it anyway. OK, so that's the first scenario. In any case you will have two white wires in the box that are only connected together, not to the switch. There will be two other wires in the box, and you have three wires on the switch. Simplest thing to do is trial and error (there are more combinations that will work, than ones that won't, and the wrong ones aren't bad, they just won't work.). OK, so take one wire of the switch and put a wire nut on it so it doesn't touch anything. Then take one wire in the box and connect it to one wire on the switch. Connect the other wire in the box to the other wire on the switch. Try it out. If it works OK, then you are good. If not, then you have chosen the wrong wire to not use. Choose a different one, and it will work.
OK now, the other scenario is that you do need a three-way switch. Same deal on the white wires as in the first scenario. But no extra switch wire in this case. Usually, two of the wires will be at the top or bottom of the switch, and third wire will be at the opposite end. The two that are at the same end are the "travelers" and the one by itself is either the hot wire coming from the electric panel or it is the output wire going to your light fixture. If you are lucky, then you will find that the wires coming into the box are a black/white/ground combo and a red/black/white/ground combo. The red and black in the red/black/white/ground combo are your travelers. The black in the other combo is the hot wire or the wire going to the fixture.
Good luck,
Al K
