2001 Suzuki GSX 750 F (Katana) Logo
Posted on Jun 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blowing main ignition and the other 10 amp fuse fuse have to wait for the bike to cool off then put new fuses in and it starts rite up, If I try to turn it over with the new fuse when its hot I blow the new fuses
bazzz7071
Level 2:
  • Expert 342 Answers
  • Posted on Jun 09, 2010
bazzz7071
Expert
Level 2:
Answers
342
Questions
0
Helped
138462
Points
692
Sounds like a short in the generator rotor magnet windings its ok until it heats up and expands then your short happens.
Hope this helps
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 • Motorcycles
How to prevent electrical short
Paul
Somewhere there is a short circuit allowing the current to flow straight to earth on the engine or the frame. Blowing a 10 amp fuse means this is a very heavy current so do not be tempted to either fit a higher rated fuse or bypass the fuse. Almost certainly this would cause burnt out wiring and possibly start a fire.
This happened when you switched on the ignition and before you pressed the starter on one occasion. On other occasions the bike has started before blowing the fuse. This suggests that perhaps wiring with damaged insulation is making and breaking contact.
You said you have a new battery. Is it possible that during the fitting of this some damage was done to the wiring? Do you have a meter or can you borrow one? See if you can find out where this current is running to earth without replacing the fuse. ie check after the fuse with a meter.
At times like this it is good to have a friend that is an electrician to help you check.
Good luck.
2003 harley davidson electraglide
main breaker/fuse will have no effect but a 50 amp breaker/fuse will cause the wiring the breaker is there to protect to melt if there is a short or other abnormal draw through it and the destroyed wiring harness(es) would probably exceed the cost of the bike to fix so do not be putting in oversize breakers or fuses.
1helpful
Put a new motor in my 1990gmc truck 1990year.It ws a 10 amp fuse for the ignition, what is wrong/blo
Hello! Just because you changed an engine does not mean that something unrelated hasn't occurred... In the fuse box is the 10A fuse in the far left row...Third fuse down?....If it is that is the ECM ignition Fuse...Tracing from the ignition switch it is a Pink wire that goes to a 3A in-line fuse and changes color to Purple/White then on to the ECM...When the fuse blows is there battery on the Pink wire?...If not...Pull the blown fuse...Disconnect the main Battery terminal...Set multimeter to the X 10 scale...Place one lead on each side of the pulled fuse socket and the other lead to bare metal ground...Does either side read resistance to ground?...If it does turn the ignition key from off...To ACC,.. to start and finally hold on run...Does the ground go away in any of those positions? if it does I would suspect one of the ignition switch wires is touching ground...Hard to find...But if you alligator clip the meter in place and wiggle the ignition wires you may see it come and go...Indicating where you are moving the harness the bare wire is pinched to ground...
However...If the movement of the key does not produce a change...Remove the fuse box...Flip it over... identify the wire on the fuse that blows and trace it with meter in-place wiggling as you move through the harness until you find the bare spot touching ground...
An easier softer way is to identify the color of the wire that connects to the ECM IGN FUSE...It will be Red, or Purple/White and go to the ignition switch...Cut it on both ends and run a wire of the same gauge from point to point...Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
92' toyota Camry - 4-cylinder....When engine is turned off after it had been running for awhile , it will turn but not start ...but after it had time to cool down for 10 - 30 min....it will start, and...
Difficult hot starting is more often caused by
- clogged air filter element
- low fuel pressure in the injector supply rail
- bad ground connection, at battery, engine block, or chassis
Check these things first. You may need to measure fuel pressure with a T-fitting and gauge. Please don't try it by running the engine and seeing how fast the fuel fills a container, that is dangerous and gives the wrong answer.
Why does my honda shadow 1100 american classic keep blowing 10 amp ignition fuse
DOES YOUR BIKE HAVE CORRECT IGNITION COIL IF IT TOO HIGHLY RATED I.E A SPORTS COIL YOU WILL PUT EXCESSIVE CURRENT THROUGH FUSE CAUSING IT TO BLOW. IS THE FUSE HOLDER SECURED DOWN VIBRATION CAN MAKE FUSES BLOW LIKE BULB FILAMENTS {TRY A 15AMP FUSE] IF THAT BLOWS DEFINATE OVER RATED COIL
Main 30 amp fuse blowing
Sounds like it is a short. Start checking all your main wiring and make sure that nothing has rubbed showing bear wire and that nothing is grounded on your system. The short in the loom if VERY common due to vibrations
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
