1996 Nissan Maxima Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sun roof won't open, but i hear the motor turning
ZJ Limited
Level 3:
  • Nissan Master 17,989 Answers
  • Posted on Jun 03, 2010
ZJ Limited
Nissan Master
Level 3:
Answers
17989
Questions
0
Helped
14459397
Points
60858
Check for any obstruction in the rail.
Also, can check this procedure to test your components...
Power Sunroof - REMOVAL & INSTALLATION (click over pic for zoom)
Motor
See Figure 1
  1. Remove the sunroof switch panel by pushing it to the side and disengaging the pawl, then pulling it downward.
Fig. 1: The sunroof switch panel is retained by a metal clip
  1. Remove the sunroof switch bracket.
  2. Unplug the sunroof motor wiring harness connectors.
  3. Remove the sunroof motor mounting screws.
Disassembly of the sunroof motor is not recommended.
To install:
  1. Lightly lubricate the drive gear with grease and install the sunroof motor to the sunroof assembly.
  2. Plug in the electrical harness connectors to the sunroof motor.
  3. Operate the sunroof to verify proper operation.
  4. Install the sunroof switch bracket and the sunroof switch panel.
Sunroof
See Figures 2 and 3
Fig. 2: Exploded view of the sunroof assembly on 1993-94 vehicles
Fig. 3: Exploded view of the sunroof assembly on 1995-97 vehicles-1998 models similar
  1. Tilt up the sunroof lid.
  2. Remove the lid side trim.
  3. Remove the lid bolts and the lid assembly.
  4. Remove the rear drain mount screws and the drain.
  5. Remove the shade assembly holders from the sunroof frame.
  6. Remove the shade assembly.
  7. Remove the sunroof switch, interior accessories and headliner.
  8. Remove the switch bracket.
  9. Remove the motor assembly, spacer and clip.
  10. Remove the wind deflector mount holders from the sunroof frame.
  11. Remove the wind deflector.
  12. Disconnect the drain hose.
  13. Remove the sunroof brackets.
  14. Remove the sunroof frame assembly.
  15. Remove the link and wire assemblies.
To install:
  2. Install the link and wire assemblies.
  3. Install the sunroof frame assembly.
  4. Install the sunroof brackets.
  5. Connect the drain hose.
  6. Install the wind deflector.
  7. Install the wind deflector mount holders on the sunroof frame.
  8. Install the motor assembly, spacer and clip.
  9. Install the switch bracket.
  10. Install the sunroof switch, interior accessories and headliner.
  11. Install the shade assembly.
  12. Install the shade assembly holders on the sunroof frame.
  13. Install the rear drain mount screws and the drain.
  14. Install the lid bolts and the lid assembly.
  15. Install the lid side trim.
Hope helps (remember rated this help).
5 Related Answers
Anonymous
  • Posted on Nov 29, 2008
SOURCE: Sun roof
This is a common issue, it is caused by a relay block that is mounted close to the sunroof motor, after time the main 2 relays on the block come loose and can be fixed by taking out and re-soldering them, i fixed mine and two other friends jeep sunroofs this way, works like a charm
Anonymous
  • 93 Answers
  • Posted on Dec 09, 2008
SOURCE: Sun Roof Motor is not closing the Sun Roof
It sounds like it can be a problem with the switch. Try pulling the switch out of the dash. Are you any good with using a Digital Multi Meter?
Anonymous
  • 51 Answers
  • Posted on Jan 17, 2009
SOURCE: closing sun roof motor bad
LOWER ROOF PANEL UN BOLT MOTOR TO SUNROOF 2-3 BOLTS REMOVE MOTOR THEN SLOWLY PUSH SUNROOF DOWN TILL IT ALIGNS WITH THE ROOF THEN REINSTALL THE MOTOR AND ROOF PANEL.
Bill Hackett
  • 383 Answers
  • Posted on Apr 05, 2009
SOURCE: sun roof does not work
Dear cz50001: there are only a few things that you, a weekend warrior can do to diagnose and/or fix the problem on your car.
Unfortunately the newer cars get, the more complex they get.
Unfortunately, your car is one which falls in the more complex category. Your car is designed with a "BODY CONTROL MODULE". This little gem gets input from nearly every electrical component in the car including the sunroof. In terms of what you can do to check it out: The fuse box inside the car has roughly 24 fuses positioned vertically 12x12. The fuse located at the lower left side of the box is a 10A "red in color" is for the sunroof. Remove it and look through it to see if it has been burned through the center. If it has, replace it and try the sun roof. If the fuse blows again, you have a short and it would be best left to a professional.
There is another set of circumstances which can occur that will render the sunroof inoperable. If the battery is disconnected or if the sunroof motor had been disconnected, the sunroof will stop operating. To reset the sunroof memory, with the key in the on position, push and hold the sunroof tilt switch in the forward (up) position until the sunroof is fully vented (tilted up) position. It should at that point operate normally. Should those two suggestions not solve your problem, it requires either a dealership with a specialized tool called CONSULT-11 to communicate with the BCM. There are some specialty shops such as mine equipped to deal with your car as well. However, most can not address this type of problem without this diagnostic tool. Good luck.
Anonymous
  • Posted on Jun 05, 2009
SOURCE: can't open a 2002 Mercedes c230 kompressor sun roof
It's typically the motors or the special drive tubes that it uses. If you here a clicking noise then the sunroof became to tight and ruined the motor gears. You can actually switch the two motors, one is for the shades and needs less power then the other motor. They are identical, switch them. Nex make sure they are very tight to the 3 mounting bolts, there is a rubber washer bushing that wears out and alloys the motor to flex too much, causing the gear mis-alignment and gear grinding. This works great I do it all the time.
1helpful
Inalfa sun roof installed 3-29-04 in a Cad CTS 2004--will slide open but will not close all the way--any ideas on what to check?
may have slipped on the track mechanism and needs adjusted custom car shop may help with this..good luck..
My 2002 toyota sequia sun roof won't open. I hear relay click when I push button. But roof won't move. The fuse is good, I checked it and also replaced it.
Hello.
It sounds like you may have a bad motor, often when a motor is weak you will hear clicking.
Donnie
1helpful
2answers
I have a 1999 ford expedition an the sunroof wont open y is that
The sun roof is an electric motor that operates on electricity provided by the battery...
Your fuse may need to be replaced in order to opperate the electric sun roof motot...
My sun roof/moon roof won't open, i can hear the motor working but it's not catching anything
The cables have become disconnected inside the roof, either broken or just unclipped, if you never worked on a sunroof it may benefit you to find a sun roof professional as to avoid any possible further problems.
Have 04 getz and sun roof wont work.stuck closed.has two control buttons,up and down and open close.thought cables jammed.popped motor off sunroof.motor only running one way.wont reverse.HELP PLEASE.
my apologies for delay in getting back to you.only just sorted this.turned out was the little control unit for sun roof causing problem.it is cable tied to the sun roof frame beside the sun roof motor and can only get at it by dropping the head cloth on one side.learned from a hyundi dealer the switches give a lot of bother,now and again the control units do too.many thanks.
2helpful
1998 Isuzu Rodeo is having issues.
check to see if AC and HEATER blower motor is getting power .if yes replace blower motor.if no you have problems in relay- fuse- or ac and heater switch is bad.for sun roof check for power at switch if yes sun roof eletric motor need replace.or sun roof in a bind.if no power to sun roof switch.blowed fuses and bulbs or turn signal switch is bad.
1helpful
Sun Roof won't open
There may be a way to open the sunroof manually by turning the motor with a tool. The motor could be broken and "free spinning" or it could be off track or something is stuck in the track. You just need to take it apart starting with the interior trim the rest should be pretty self explanitory. You may also be able to find a diagram on www.autozone.com.
1helpful
85 Toyota Cressida. The Sun roof is stuck open!
I was lucky, the owners manual was still with the car and it addressed this problem. Tells you to remove the cover for the controls to the sun roof. Then remove the screw plug that is located in the forward left side of the control box hole (Need big screw driver to break it lose). Then remove the slug surounding the inner adjustment screw, being careful not to lose any shims or washers. Trun the adjustment screw counter clock wise to close the sunroof down and clock wise to shut the sunroof from the open position.
Looks like the motor is shoot. To prevent this from happening again I disconnected the white with black strip wire to the control pad and unsulated the lead. It can easiely be hooked back up in the future if the motor is replaced.
Good luck all!
1helpful
4answers
Sun roof will nt close cant find the rite fuse
check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
Headliner must be removed to access motor.
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel water trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse
  • Circuitry
  • Accessory delay relay
  • Roof opening panel switch
  • The roof opening panel does not open or close
  • Roof opening panel adjustment.
  • Battery junction box (BJB) fuse.
  • Circuitry.
  • Roof opening panel switch.
  • Roof opening panel motor assembly.
  • Roof opening panel lifter assemblies.
  • The roof opening panel does not open or close — one direction only
  • Circuitry.
3helpful
3answers
Sun roof will open but not close
there is a manual way to close it. between the rearview mirror and the sunroof there is a plastic box remove the two screws holding this on and remove. then with a flat tip screwdriver depress the white plastic clutchpinin the center of the motor screw.(this should be towards the rear of the area).turn this white plastic pin to open or close your sun roof. i hope this helps.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
