There are some capacitors in the power supply that may have gone bad. You will have to take the monitor case apart to get to the power supply. Start with a small flat blade screwdriver at the bottom of the case and pry gently to get the case open. Be careful of any wiring attached to the front bezel. Once you have it taken apart, inspect the caps on the power supply. Check if any are leaking/bulging, if so...that is probably the culprit.
You can purchase a repair kit from
lcdalternatives.
The site also has a installation tutorial on replacing the capacitors.
