I am unable to locate the choke on my powerwasher. Where is it located?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
The front choke on a motorcycle is typically used to help start the engine by enriching the fuel mixture when the engine is cold. The choke is usually controlled by a lever or button located near the throttle, and is typically only needed when starting the engine from a cold state.
To connect the front choke on a 2000 Suzuki Intruder 1400, you will need to locate the choke cable and follow it to the carburetor or throttle body. The choke cable will typically have a small lever or plunger at the carburetor end, which is connected to the choke mechanism inside the carburetor or throttle body.
To connect the choke cable, you will need to attach one end of the cable to the lever or button near the throttle, and the other end to the lever or plunger at the carburetor end. Make sure the cable is properly seated in the levers or plungers and can move freely.
It's important to note that every motorcycle is different, and the specific choke mechanism on a 2000 Suzuki Intruder 1400 may differ from the general information I have provided. If you are having difficulty connecting the choke on your motorcycle, it is always best to consult a service manual or a wiring diagram specific to your make and model.
