Pride Celebrity Deluxe Mobility Scooter - Serial Number
I have a Pride Celebrity Deluxe (4 wheel) approx 2007 bought in the UK second hand. Where is the serial number on the scooter? I need it for insurance.
Re: Pride Celebrity Deluxe Mobility Scooter - Serial...
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Neil is right, the serial number is on the seat support. From that the year can be determined. It's mostly moot, as Pride only has a 1 year warranty, and after that, it Parts and Labor. Why are you asking?
I can send you the manual (PDF) if you send me your email address. My address is (D*H*u*d*s*o*n at GMail dot com), you need to take the stars out and put the @ symbol in and the .com to make it usable.
